Well here we go:
1. I put the Z-stick(v2) in the exclude mode -> push button 3 sec -> light blinks fast
2. I put the module (AN157-2) in the power socket -> the light on the module blinks
3. I push the on/off button on the module. -> light on the module button turns on, module is on.
4. I push the on/off button on the module. -> light on the module button turns off, module is off.
5. I push the on/off button on the module.. -> light on the module button turns on, module is on.
6. I turn the Z-stick off
I keep the module in the power socket
7. I put the Z-stick(v2) in the include mode -> push button -> light blinks 'normal'
8. I push the on/off button on the module. -> light on the module button turns off, module is off.
9. I push the on/off button on the module. -> light on the module button turns on, module is on.
10. I push the on/off button on the module. -> light on the module button turns off, module is off.
Nothing happends on the Z-Stick. According to the manual it should display a solid 3 second light on the stick when it registers a new device.
I remove the module from the power socket.
11. I put the Z-stick(v2) in the include mode -> push button -> light blinks 'normal'
12. I put the module (AN157-2) in the power socket -> the light on the module blinks
13. I push the on/off button on the module. -> light on the module button turns on, module is on.
14. I push the on/off button on the module. -> light on the module button turns off, module is off.
15. I push the on/off button on the module.. -> light on the module button turns on, module is on.
I downloaded the latest EU firmware for the Z-Stick(v2), flash, did the include proces again... nothing...
I also own a HomeSeer PRO copy (for X10 until now..). Could this help to troubleshoot ?
