Hi
Which Jung pulse switches do I have to order for the KAKU AMWR-230 module?
Right now I'm using the original switch.
Thank you!
DJ
Jung pulse switch for KlikAanKlikUit?
- Jeroen Bartels
Re: Jung pulse switch for KlikAanKlikUit?
I think you need to connect some kind of transmitter to any pulse switch. And that transmitter needs to be Kaku ready or have everything run through HS.
**Jeroen**
Jeroen,
Don't care about homeseer status unless there's an easy solution with KAKU modules.
With this solution I can control the lights using
- HomeSeer
- Local switch
- Remote (through a motion sensor+HomeSeer for example)
Just need to find out which pulse switches I have to buy for these KAKU devices.
Cheers
DJ
- HomeSeer
- Local switch
Cheers
DJ
