What functionality do the features below serve?
<ul><li>Auto Acknowledging</li><li>Auto Power</li><li>Load Status (Status Belasting</li></ul>
Do I want these features enabled and why? Does the Load Status feature also transmit messages when the load is <i>removed</i>? Why did the put these features on a DAIX10 module?
How about those nice Xanura micro module features?
Hi Mindbender,
Autoacknowledge enabled the module will send his status after the module has been switched by a command. So just like the word indicates.
Autopower enabled will make the module switch on when a load (resistive) is connected to the module.
Load status enabled the module will acknowledge that the module is switched on by sending its status.
All these features are also available on the DAIX10. Eaton has removed the functions from the label but not from the module.
Good luck.
Good luck.
