When i try to load the project into gambas2 i get the following messaga:
"Sommige componenten worden gemist: gb.db.form, gb.db.mysql, gb.net, gb.net.curl, gb.net.smtp, gb.web, gb.xml, gb.xml.rpc"
How can i add these components?
Greetz
Error installing domotiga
Moderator: RDNZL
- RDNZL
Re: Error installing domotiga
It depends on how you installed Gambas.
If you have compiled it from svn/source code, you are missing some system development packages for those components.
Install them (look at the Gambas install page on domotiga.nl) and recompile/install.
If you installed gambas from a package manager simply look up those packages and install them too.
Gambas is made out of seperate parts, if you want them all install the package called Gambas IDE.
If you Linux distro isn't listed on domotiga.nl you can look at the Gambas homepage, or else post it here.
Regards, Ron.
Found it. The packages do not get installed when you select it from the software centre
