8 Relay Server IP Ethernet IP-X800 pro
Posted: Sun Jul 18, 2010 1:50 am
Hello
Starting in home automation and discovered the card IPX-800 from GCE I want to know if anyone knows this and is it a good investment to get started in home automation.
Some information about this material
Map 8 relay IP web server
Plug and Play!
Configurable DHCP or IP FIXED
Secure Access by login
Telnet server
8 relay outputs 230V / 5A max
4 digital inputs for contact or limit
The website is fully customizable board (HTML, XHTML, Java, CSS)
7.5VDC to 12VDC power supply (not supplied)
Two 10-bit analog inputs for resistive sensor (Potentiometer, LDR, etc. ...)
The link about this item
gce-electronics.com/tcp-ip/31-serveur-i ... ernet.html
Another question:
What is the most flexible platform for a project automation.
Windows ?
Linux ?
Mac ?
Yannick
Plug and Play!
Telnet server
Another question:
Windows ?
Linux ?
Mac ?
Yannick
