Xanura SAX1 broken ?
Posted: Fri Jul 23, 2010 1:32 pm
by Harry
i have now a SAX1 module ,that do's not respond anymore.
the red led is not blinking, it only go's on when i push the set button.??
the module workt fine for two years now, but in the time i have replaced all the outside lamps for powersavers (spaarlampen).
do's anyone now if the SAX1 can handle these lamps.
Re: sax1 broken ?
Posted: Fri Jul 23, 2010 10:33 pm
by TANE
Sax1 will switch any connected device or light.
Re: Xanura SAX1 broken ?
Posted: Tue Feb 15, 2011 9:51 pm
by Harry
today another sax1 broken
, is this a nown problem.
is there something i can do ?
what is a good replacement of these devices?
Posted: Tue Feb 15, 2011 11:27 pm
by TANE
This is a known problem of the old saix and sax1.
repair is not possibile...(almost)
Replacement in X10 is SAIX12
other alternatiefs are zwave
Posted: Tue Feb 15, 2011 11:54 pm
by Harry
i am thinking to add zwave to my system, what unit could be a replacement. what kind of reach has zwave
Posted: Wed Feb 16, 2011 12:02 am
by Rene
My first series Xanura modules I bought were of the second generation SAIX, SAX1, DIX from Eaton. Last year I bought some additional modules from a fellow forum member, which were of the first generation from Holec. Two modules of these, the Holec ones, broke within a year. Another post on the forum (
http://www.domoticaforum.eu/viewtopic.p ... 00v#p27389) describes a possible way to repair the broken modules, by replacing the 1uf/400V elco. This weekend I ordered a couple of those elco's and as soon as they arrive I will try if I can repair the modules. Maybe this also works for you.
Posted: Wed Feb 16, 2011 12:14 am
by TANE
Harry wrote:i am thinking to add zwave to my system, what unit could be a replacement. what kind of reach has zwave
The current available zwave switches are
Duwi
Act
Merten
In zwave is distance to a device not a big issue since it will use other device as router to reach the device that are not so close to the zwave interface.
This is called mesh network.
http://en.wikipedia.org/wiki/Z-Wave
Posted: Wed Feb 16, 2011 12:35 am
by Harry
This weekend I ordered a couple of those elco's and as soon as they arrive I will try if I can repair the modules. Maybe this also works for you.Rene.
where dit you orderd the elco's?
Posted: Wed Feb 16, 2011 10:17 am
by Rene
Conrad, productnr 445492. Maar ik weet niet zeker of dit de goed zijn (afmetingen). Ik heb ze nog niet binnen, dus als je effe wacht tot ik ze heb kan ik je zekerheid geven.
Posted: Fri Feb 25, 2011 9:01 pm
by Harry
hoe is het afgelopen? is het gelukt
Posted: Fri Feb 25, 2011 10:44 pm
by Rene
Het waren niet de goede, ze zijn een millimeter te breed waardoor ze er niet tussen passen. Ik moet nog op zoek naar een ander type.
Posted: Mon Feb 11, 2013 9:49 pm
by Harry
what is the status , could you find the correct elco?
