Differences between MS13A and MS13?
Posted: Sat Oct 20, 2007 2:30 pm
by PietjePuk
In one of topics in this forum I have read the MS13A (American version) is much more cheaper than the MS13 (European version). At this moment I have already a TM13 receiver. Does any one knows if the TM13 can receive and decode the X10 signals from the MS13A? Are there differences between the MS13A and Europe version?
Posted: Sat Oct 20, 2007 3:38 pm
by b_weijenberg
The European TM13 is NOT able to receive the MS13A.
The U.S. X10 devices transmit at a different frequency.
U.S. X10 transmits at 310MHz while the European X10 transmits at 433.92MHz.
Posted: Sat Oct 20, 2007 5:09 pm
by PietjePuk
Thanks for your answer. But is it possible to use the MS13A in the Netherlands? If yes, which receiver do I need to receive the signals from the MS13A (the receiver must work at 220V)?
Posted: Sat Oct 20, 2007 5:37 pm
Hi
RFXcom has also X10 reveivers for on 310MHz, I'm not sure they can deliver them in the netherlands but you can always ask.
www.rfxcom.com
Posted: Mon Oct 22, 2007 11:39 pm
by PietjePuk
Is it also possible to use a MS13A with the TM751-transceiver module (with a voltage converter eg. "http://www.elecshop.nl/nl/dept_7.html") to be able to control a european LM12-lamp module? (Then I don't need to buy an expense RF receiver from RFXCOM.)
Posted: Tue Oct 23, 2007 8:48 pm
Looks like it's possible, I have no experiance with this module.
