this is my first post.
I did got monday my new rfxcom power modules.
After a new installation (ubuntu + gambas + domotiga) i realised that my
version on startup is 1.1.183 and not 184.
I did a new install en the upgarde script to 184 is on my system.
I dit run the upgrade script (manual) nothin changed.
What is wrong?
Thankz in advance
version 0.1.184
Moderator: RDNZL
Re: version 0.1.184
How did you do the installation??
Did you do a recompile of the code, or do you use a pre-compiled binary??
- Starting Member
Re: version 0.1.184
i did :
$ mkdir -p ~/install
$ cd ~/install
$ svn co http://svn.domotiga.nl/domotiga/trunk/ domotiga
I dont reminder a recompile.
In the upgrade folder i found the upgrade sql to the higher version.
thankz,
$ cd ~/install
thankz,
- RDNZL
Re: version 0.1.184
In this release only the source code was updated.
The binary files DomotiGa.gambas and DomotiGaServer.gambas are still at 0.1.183.
But don't worry you can create them yourself easily.
Simply start Gambas IDE from cli/shell by typing gambas2, or use the Gambas2 IDE icon from your desktop menu.
Load the DomotiGa project by choosing file -> open project -> browse to /home/dir/domotiga/DomotiGa (or Shortcut Ctrl-O)
This will load the project, code and GUI's in the IDE, then you can choose compile and create executable from menu Project -> Make -> Executable (or Shortcut Ctrl-Alt-M) and save it over existing DomotiGa.gambas file.
Then you should have 0.1.184 in title bar after starting. Same procedure can be used for DomotiGaServer.
And if your executable has a higher version than the database, the database upgrade should start automatically if needed.
Let me know if this is clear and fixed your problem, I can document it more on the wiki.
Regards, Ron.
- Starting Member
Re: version 0.1.184
thankz, this did the job,
I now have the right version.
Re: version 0.1.184
If you're running on something without a graphical interface, like me, you can remove the old binaries, and use the tools/startserver script to start the server version.
you'll have to upgrade the database by hand though.
- Starting Member
Re: version 0.1.184
I am running domotiga on a IBM R52 laptop for testing.
This is not my final situation * i think). I'll seek an low power unit in the future.
I have Ubuntu installed with the graphical interface and the software is up and running.
There is stil a problem with my rfxcom 3 fase power meters.
I get in the log the message that only 1 module is supported.
I can't get the graphis working for the 3 modules and only the total usage is visible.
Every meter is reporting (i see this in the debug log)
Thankz in advance.
Thankz in advance.
