Rfx Visonic receiver antenna
Posted: Fri Oct 26, 2007 1:20 am
Hi All
Good to see you in that great site
I have a 492Mhz Visonic USB receiver and I'm experiencing problems with the receiving of signals of remote rooms. It seems that the default wire antenna is not enough to receive signals
I have read the documentation and it is mentioned that the wire antenna can be changed by a 50 ohm coax antenna.
My question is, how this can be done? Can someone send me detailed instructions on how to do that?
I have seen J1 and J2 ports in the PBC, but I do not know how to connect them to the coax antenna.
Will the reception be improved with this?
What is the size of that cable that I must use?
Many thanks in advance
Best regards
Juande
Best regards
Juande
