New Pan Tilt and Zoom webcam Installed
Posted: Sun May 14, 2006 12:31 am
I installed a new webcam installed on bwired.nl http://www.bwired.nl/Camfront.asp.
This Pan Tilt and Zoom Camera is a customized Sony EVI-D30 CCD Camera and is located at the front of my home.
The camera was part of a ISDN conferencing kit the PCS-1600 http://www.bwired.nl/images/how/PCS-P160P.pdf.
I dismounted the camera of the unit and figured out the video, power and RS232 outputs from a 15 pin connector in the camera.
The camera module is a the same as the the SONY EVI-D30 / EVI-D31, just some other connectors.
You can control the camera by clicking the presets.
Only Presets are available for this camera and at Night Time the camera will turn it self automaticly off,
Sunset en sunrise are also automaticly adjusted for camera On and Off control by my Home automation system.
The camera is mainly used for weatherimages which can be seen on the Bwired Weatherpage http://www.bwired.nl/Weather.asp as well.
The software for controlling the cam is self written In Visual basic.
