Availabilty Forum on Nitroserve (ervaringen Nitroserve)
Moderator: TheHogNL
- Snelvuur
Re: Availabilty Forum on Nitroserve
First had a timeout in firefox, then i got:
PHP Fatal error: Maximum execution time of 30 seconds exceeded in \\files\localuser\domotica\pkk\includes\functions.php on line 1076
tested it from different hosts too, one other host was "slow" while the other host was faster.. i could visible see the difference. (connections from 2 different boxes in germany)
- Willem4ever
- Global Moderator
64 bytes from 84.243.195.130: icmp_seq=15 ttl=122 time=12.307 ms
64 bytes from 84.243.195.130: icmp_seq=15 ttl=122 time=13.271 ms (DUP!)
64 bytes from 84.243.195.130: icmp_seq=15 ttl=122 time=13.474 ms (DUP!)
64 bytes from 84.243.195.130: icmp_seq=15 ttl=122 time=13.661 ms (DUP!)
64 bytes from 84.243.195.130: icmp_seq=15 ttl=122 time=13.857 ms (DUP!)
64 bytes from 84.243.195.130: icmp_seq=15 ttl=122 time=14.063 ms (DUP!)
This behaviour, duplicate pings replies, isn't good either ....
- Snelvuur
indeed..
--- www.domoticaforum.eu ping statistics ---
7 packets transmitted, 7 received, +35 duplicates, 0% packet loss, time 10074ms
rtt min/avg/max/mdev = 15.529/15.977/16.709/0.373 ms, pipe 2
I think that the problem is the database.
As the databse server is on an other IP address than the website, pingin the website does not make sense to me.
- Snelvuur
We are just saying that its not normal to get such a reply back, ofcourse we "assume" the database server is on another box.
Now it has added pkk in adress, some backup thing going on?
Will be fixed soon, no backup recovery.
Did some changes in DNS, causing this and not being avalaible for some time.
Thanks
Thanks
18:33
HTTP Error 500.0 - Internal Server Error
Module FastCgiModule
Notification ExecuteRequestHandler
Handler PHP via FastCGI
Error Code 0x00000000
Requested URL http://www.domoticaforum.eu:80/index.php
Physical Path \\files\localuser\domotica\pkk\index.php
Logon Method Anonymous
Logon User Anonymous
ik kreeg dit net:
20:51 and 21:08
Is gemeld, wordt aan gewerkt!
dank
dank
en nu net deze:
Moets ook een nieuw ww aanmaken. Kwam er niet meer in met mijn oude
En bij mij was het forum een maand in de tijd teruggezet... naar 26 oktober??? Geen post uit november meer te vinden!
5 min. later was het weer OK...
Momenteel ondervindt een deel van ons netwerk problemen met de MySQL en MSSQL verbindingen. Deze problemen hebben te maken met hardware problemen op de primaire database server. Momenteel wordt er door onze technische afdeling gewerkt om dit zo spoedig mogelijk op te lossen. Door de huidige problemen kan uw website, indien u gebruikt maakt van een MySQL en/of MSSQL database, vertragingen ondervinden. Later deze avond en wellicht dit weekend kunnen er onderbrekingen ontstaan i.v.m. de hardware matige werkzaamheden aan de server.
Onze excuses voor het ongemak.
Onze prioriteit ligt bij het oplossen van het hardware probleem. Uw vraag of opmerking kan daarom met vertraging worden verwerkt. Indien wij meer informatie hebben dan laten wij u dat via de e-mail weten.
- Snelvuur
26-11 kreeg ik een mailtje dat er wat gepost was hier, toen kon ik niet eens kijken. Ik kijk vandaag weer eens en het duurt gewoon 15 seconden om in te loggen, daarna nog een keer 15 seconden om in dit topic te komen.
Het is nu 01:41 snachts, ik kan me niet voorstellen dat na deze dagen het nog zo slecht is en dat het op dit tijdstip "druk" is.
Problemen met de primaire database server, dan draai je toch lekker verder met de secondary? Ik kan slecht programmeren maar een clustertje mysql maken kan ik ook nog wel.
Aanbod staat nog steeds pieter.
