'Save' button RFXCOM plugin?
DJF3
Post by DJF3 »
When I open the RFXCOM plugin (input devices for example) there is a 'Save' button.
What exactly does this button do?
Documentation:
Save button
This will save the selections made in the 3 selection boxes.
- What are the 3 selection boxes?
- Do I need to use this button after making changes to devices?
- Is this only for the check-box (use on/off status for AC devices)
Thank you!
DJ
b_weijenberg
Re: 'Save' button RFXCOM plugin?
Post by b_weijenberg »
De SAVE knop op de Input Dev pagina is inderdaad alleen om de selectie van "Use On/Off status for AC remotes" te saven.
Op de General en X10 pagina's worden alle setting van de pagina gesaved.
Op de Security pagina worden alle instellingen gesaved die net boven de SAVE knop staan.
En op de Output Dev pagina wordt de AC extended address code gesaved.
