Last week I did some test wit the Marmitek Powermid Dual Power.
I was hopping to have a cheap solution for remote control extender.
to bad this unit is not working well in my house, is to much interfering with other device on 433 Mhz
I'm going to try the IR Control Pro8 from Marmitek.
This one is not using RF.
anyone positive experience with the last one?
thanks
Powermid Dual Power
Powermid Dual Power
I have that device from Marmitek that sends your IR signals (2-way) over your Cable infrastructure. This works great. The only disadvantage is that you can only use it where you have TV cable.
[http://www.marmitek.nl/en/catalogus/pro ... roduct=270
DJ
DJ
Powermid Dual Power
thanks...that's my problem..I don't have cable in every room.
