Deursensor
Moderators: Rene, Willem4ever
labtec
Deursensor
Post by labtec »
Ik zou graag een deursensor willen gebruiken icm met een RFXcom receiver (USB), nu blijkt dat het bereik
van de Marmitek DS90 niet erg groot is door vloer/muur ongeveer 10 meter (USB RFXcom receiver staat op de 1e verdieping, deursensor op beg.grond).
Kan ik dit bereik verbeteren? ander merk/type deursensor? of?
Re: Deursensor
There are two options:
Visonic MCT-302 (For the Rfxcom you need the receiver 868 version)
Zwave door window sensor(like the Everspring Sm103) (for zwave you need a zwave receiver like the Aeonlabs USB stick)
Re: Deursensor
Visonic is indeed very reliable.
20 m through 2 walls is OK here.
labtec
Re: Deursensor
Post by labtec »
So I can use Zwave or Visonic components. In this case what is the best solution? I understand that when I want to use
Visonic I need a additional receiver in my USB RFXcom, and with Zwave I need a receiver USB stick.
Re: Deursensor
Both will work fine.
In case of zwave you can associate the sensor directly to the device that you like to controle.
This means' door open lights on. It will also work when Homeseer or other software is not running.
Other benefit of zwave is that the protocol is using mash network.
This means that the sensore will use other zwave devices to reach the software or the device that you are going to control.
This way you can reach devices that are to far from you system.
This is called routing.
for a review of the Everspring SM103 see my blog.
(Dutch)
http://blog.tane.nl/?p=178
labtec
Re: Deursensor
Post by labtec »
OK, thanks! So I only buy an Zwave USB stick (receiver), the plug-in for HS is free? after that I can use all Zwave devices?
My PC running HS and the RFXcom receiver are on the first floor, is it for Zwave no problem to receive the signals
via the USB stick?
Re: Deursensor
There is no need for a plugin.
In Homeseer there is support for zwave.
Beste is to have more than 1 zwave device. this will make you zwave network strong.
If you have a zwave device at every floor the signal will reach every device.
For more info about zwave check my blog. More zwave devices are reviewed.
http://blog.tane.nl
for more info feel free to contact.
Re: Deursensor
@Tane
I have a quetion about z-wave
Will it also send back status like in this scenario.
A switch controls a lamp. Will the lamp signal back that it has recieved the command and is turn on?
Alexander
Re: Deursensor
Post by Alexander »
Depends on the zwave device.
Alexander
Re: Deursensor
AshaiRey wrote:@Tane
Everspring SM103 will report te status
Also the Everspring plugin switch will report the status.
http://blog.tane.nl/?p=199
labtec
Re: Deursensor
Post by labtec »
Wat zijn de ervaringen met onderstaande Z-wave receivers;
- ACT Homepro
- Seluxit viaSens 100
- Tricklestar USB adapter
- Aeon Labs Z-stick
Heeft een bepaald model de voorkeur, mogelijkheden, bereik, etc?
Esteban
Re: Deursensor
Post by Esteban »
Please, keep it in english, thanks :)
labtec
Re: Deursensor
Post by labtec »
Esteban wrote:Please, keep it in english, thanks :)
What is your experience with the following PC receivers;
- ACT Homepro
- Aeon Labs Z-stick
Preference type/model, features, range, etc
labtec
Re: Deursensor
Post by labtec »
What receiver is the best? range?
- ACT Homepro
- Aeon Labs Z-stick
Esteban
Re: Deursensor
Post by Esteban »
Remember that Z-Wave devices form a mesh network, so range is not that important for your choice of dongle.
