Is it possible to use a security panel like BLsecurity in HStouch? I want to use security options in combination
with HS2 and HStouch, i.e. different use of sensors in home or away mode. I also have a Marmitek SC9000
may-be is a cobination of all components possible?
When I install BLsecurity can I see the security panel in HStouch (Ipad, Iphone) of only with the browser?
BLsecurity
Re: BLsecurity
Most of the plugins will also show the info in HSTouch.
why use BLsecurity if you have Rfxcom plugin?
- b_weijenberg
Re: BLsecurity
Here is an example of the RFXCOM security panel in HSTouch http://board.homeseer.com/showthread.php?t=131873
Re: BLsecurity
Bedankt! ik ga mij erin verdiepen
