What does RecLog.txt do?
DJF3
Post by DJF3 »
In the \HS\Data\RFXCOM\ directory there's a file called RecLog.txt.
- What does it do and how can it be important?
- How can you prevent it from growing?
Thank you!
DJ
b_weijenberg
Re: What does RecLog.txt do?
Post by b_weijenberg »
Please contact support rfxcom.com for a solution.
Alexander
Post by Alexander »
@Bert: Could you please answer the questions publicly so everybody can understand the situation/solution.
Alexander
b_weijenberg
This is a function "FOR INTERNAL USE ONLY" and should not have occured.
If this problem exists you can contact support to solve this.
