HA7Net and DomotiGa
Posted: Mon Jan 31, 2011 6:57 pm
by Bororo
Dear Friends,
I went through this forum seeking for answer and found several topics where HA7Net was mentioned.
I already know about HA7Net capabilities and support for 1-wire IC's.
What is not clear for the moment is DomotiGa support for this device.
I'm planning to connect several temperature sensors and few counters to HA7Net, but I would like to know If others steps needs to be done before I'll see all this stuff available in DomotiGa. All I know about 1-Wire support is that DomotiGa accessing 1-wire sensors via Midon TEMP08 interface, or using a DS9079(U) interface together with digitemp and the last one is using OWFS.
Will I see 1-wire devices connected to HA7Net in DomotiGa without installing Digitemp or OWFS?
Many thanks in advance.
Re: HA7Net and DomotiGa
Posted: Thu Feb 03, 2011 9:35 pm
by RDNZL
DomotiGa has support for 3 different 1-wire interfaces and you have one with isn't one of them :roll:
I cannot get clear what protocol the HA7Net device uses, only some vague description about using http and ssl.
If you can show me some to the point documentation or example code in vb I will see what I can do.
Posted: Thu Feb 03, 2011 11:06 pm
Ron, there's nothing vague about the HA7Net; if you need a manual (on which I based my HA7Net interface), I can send it to you.
With (Delphi) code, if you want to. Although I can imagine you don't like writing code for a device you don't have yourself.
Posted: Fri Feb 04, 2011 1:11 am
by RDNZL
Robert, i'm interested in both.
DomotiGa supports hardware which I don't have already, eib/knx, ezcontrol, currentcost are some of them, the first one is rewritten by myself.
I don't have problems with that at all, the problem's I do have are lack of time and defining priorities.
But i'm not the only one I guess :mrgreen:
Thanks in advance!
Posted: Fri Feb 04, 2011 1:52 am
Ok, I'll send both (soon :) )
