Page 1 of 2
New Toilet reading setup and graph
Posted: Wed Dec 05, 2007 1:02 am
On 2-10-2005 I installed wireless sensors (MS13) on our Toilets, up- and downstairs to see real-time how many times the toilets are flushed.
On 11-11-2007 I upgraded the toilets with a water saving dual flush system (3 versus 6.5 liters) So I replaced the Marmitek MS13 sensor for the Visonic MCT-100 which has 2 inputs which I can use for Water-saving and normal flush reading. So now it's possible to show how many water you can save a year with a watersaving mechanism.
<b>Magnetic switches inside the flushing mechanism</b>
<b>Magnetic switches connected to the Visonic MCT100</b>
<b>Final result</b>
Pieter Knuvers
Posted: Wed Dec 05, 2007 1:24 am
by Snelvuur
nice.. now all you need is to build the oregon scale in the toilet so you can weigh your poo..
Posted: Thu Dec 06, 2007 1:31 pm
by Niknik
ahahha, don't give him more ideas!
Posted: Thu Dec 06, 2007 2:10 pm
right:-) Heino, writer of the book Domotica
http://www.domoticaforum.eu/forum.asp?FORUM_ID=30
Has a complete automated toilet which even flushes automatic, so there enough possibilities.
I just want to show how much water saving you can achieve with a dual flush system in a normal familie
I wil put op some extra charts soon.
Posted: Thu Dec 06, 2007 3:38 pm
by Snelvuur
Yes, its really nice to see how much a difference it is.. you can also check if the toilet seat is "pressed" for more then xx seconds, you should flush once released. Dont know how you would do the rest, but its a start
(assuming the guys pee sitting down then)
Posted: Mon Dec 10, 2007 12:08 am
by DJF3
Where did you get the sensors. The MCT-100 doesn't come with the actual sensors. You mentioned magnetic sensors, do you have more information about these?
Thanks
DJ
Posted: Mon Dec 10, 2007 12:39 am
They are just magnetic alarm sensors you can get them at Conrad. Two of those can be connected to the Visonic MCT-100.
Look closely on the pictures and you see the sensors and piece of magnetic glued to the flush mechanism.
There are a lot of different Magnetic Contacts like these:
Regards Pieter
Posted: Tue Mar 04, 2008 2:58 pm
by DJF3
Brilliant... Ordered a cheap magnetic sensors at waakzaamwonen together with the Visonic MCT-100.. Will have to replace the magnets with smaller ones or saw then in half. Will post update once its working.
Unfortunately I have to open the MCT-100 and take out the electronics. The box doesn't fit behind the toilet-switch.
Posted: Tue Mar 04, 2008 3:34 pm
DJ,
I have also opened up the magnets and there where 2 small ones inside. If you make them to big then the flushing mechanism does not work optimal. Opening up the Visonic MCT-100 problem, try to install it not direct above the water in case of damp.
Keep us posted
Posted: Wed Mar 05, 2008 12:39 am
by esschenk
Hello pieter,
I'am a new user with home control
Can you tell me what can't of receiver you are use sing, to receive the signal from the Visonic MCT-100
And is this also working on homeseer.
thanks
Ed
Posted: Wed Mar 05, 2008 12:54 am
Hi Ed,
I and a lot of other forum members use the RFXcom receiver from
www.rfxcom.com. It can receive a wide range of products and fully compatible with Homeseer.
check out this forum with all the topics
http://www.domoticaforum.eu/forum.asp?FORUM_ID=27
regards Pieter
Posted: Sun Mar 09, 2008 10:08 am
by DJF3
I'm pretty close to getting the MCT-100 installed in my toilet now.. Next steps:
-fine tuning to get the correct readings (sensor/magnet placement)
-get smaller magnets
So there's 2 bars. The white one is for a big flush and the green one is for a small flush.
-Press green bar: green+white bar move backward a little
-Press white bar: only white bar moves.
It looks like your setup your system in a way that:
-The white bar only gets triggered if the magnet moves away (i.e. being pressed all the way)
-The green bar only gets triggered when the magnet comes near
Is this correct?
DJ
Posted: Sun Mar 09, 2008 12:24 pm
Hi DJ,
In my situation the White and the Green bars are reacting the same way, the are pushed independently from each other.
Eco flush the green bar will move backwards normal flush the White bar will move backwards
Pieter
Posted: Mon Mar 10, 2008 11:37 am
by DJF3
So if the ECO bar is pushed backwards, the white bar also moves backwards. Doesn't your system count this as 2 flushes as both magnets pass the sensor?
Posted: Mon Mar 10, 2008 12:05 pm
No only the green one!
