I will use a RF doorbel system 434MHz in a dollhouse ... the doorbell - transmitter will be very close to the receiver -a couple of centimeters ... I notice that this will not work reliable .... no problem when the distance is a couple of meters ... but within one meter problems will happen. I try to pack the doorbell tranmitter in aluminium foil to weakening the signal but that doesn't help.
Anybody an explanation and may be a solution ?
Henk
RF doorbell signal
Re: RF doorbell signal
difficult, its overloading
put a wire in between
