Sole Vento AE 1437 rolshadeshutter from 2004
Posted: Sat Apr 02, 2011 3:11 pm
by labium
i want to control my sunshade with domotica x10
this switch is installed with my sunshade. i cant google it .
it has a wind input (vento) and sun input (sole) and a connection to a motor
the little green things are the input from wind and sun
the big green thing is the motor connection
pin 7 brown the home voltage 230 volt L
pin 6 blue the home voltage o volt N
pin5 blue to com port motor
pin 4 wite to make the moter rol the shade out 0 volt to N not in function, 230 volt to N in function, 50 volt if pin 3 is 230 volt
pin 3 red to close the shade 0 volt to N not infunction, 230 volt to N in function, 50 volt if pin 4 is 230 volt.
4 and 3 seem th control moter up and down but wath is the 5 ? it mentions com ?
the brown 230 volt home current also goes directly to the motor, so what is com on pin 5 for ?
i have sw10g with up down L and N pin can i just put them parallel to this sole vento switch ?
Re: Sole Vento AE 1437 rolshadeshutter from 2004
Posted: Sun Apr 03, 2011 10:04 pm
by Henk
My quess is that pin 5 in equal to pin 6 - it is the common N (blue) ...
you should not put a SW10 switch parallel to this controller !!! It may damage the motor.
Henk
Posted: Mon Apr 04, 2011 10:29 am
by Henk
There is may be a way to use the SW10 controller - but you will need two 230V relays on the output of the SW10 to disconnect the power of the Sole Vento controller on pin 7 ...
so when the SW10 will be active the Colve Vento controller will be withour power.
Henk
Posted: Mon Apr 04, 2011 12:03 pm
by labium
thank you for your contribution.
i found an old oregon windsensor on the attick and i wil buy a uv sensor from oregon then the software of homeseer can control the sunshade.
the installed solarsensor has high resistance on darknes and low on sun, the windsenor vice versa.
there are now resistnace meters known for domotica ?
labium
