Homepro controller
Posted: Tue May 03, 2011 8:59 pm
by Wim2008
In my home I have some Merten duall wall controllers, but I saw on internet that the Homepro dual wall controller is a little bit cheaper then the Merten.
In my domotica system I use Aeon stick as secondairy controller. The Merten stick is primarily.
Will both switches of the Homepro dual wall controller work in my configuration?
Has someone some experience with the HomePro dual wall controller.
B.R. Wim :) :wink:
Re: Homepro controller
Posted: Wed May 04, 2011 9:05 am
by TANE
Homepro controller will work fine in with merten and Aeon.
Homepro stopped the production and is developing new products. You can only but from old stock
Quality of the merten products is 100% more solid than Homepro.
Last point all the Homepro wall controllers are power line powered..merten is battery powered.
Posted: Wed May 04, 2011 11:04 am
by Wim2008
Enver, thanks for your info.Both switches will work fine in HS if the aeon stick is secondary?
What does it means 'by old stock'. Can't I buy those switches in a few months?
B.R. Wim :) :wink:
Posted: Wed May 04, 2011 12:48 pm
by TANE
Most of the ACT products are EOL
no info available about the new ones.
If you are using Merten my suggestion is go for Merten...it will cost you 15 euro more .. quality is much better.
Posted: Wed May 04, 2011 4:18 pm
by Wim2008
Thanks.
