Kaku and newbie questions...
Posted: Sun Jun 12, 2011 8:53 pm
I'm glad that I found your great informative forum! I'm a newbie in domotica and want to start slowly. I realise there is a lot to learn and one better decides at the start in what system to invest. My choice for KAKU is clear already, the KAKU components are widely used and it seemes most people are happy with the value for money this system offers.
Now I plan a very simple home 'security' system by timed house lights control, garden motion triggered lights and window/door sensors to activate an acoustic in-house alarm. I searched this forum for answers first, but failed to find them. So I have following question on which I hope you can answer;
- Can 2 pieces AC-1000 (working on different codes) be stacked into the same wall socket? One AC-1000 to switch on/off an acoustic alarm horn by motion detector PIR-2050 and several door/window contacts AMST-606, and the other AC-1000 to switch on/off that alarm function by WST-8800 or remote control KCT-510?
- Can indoor motion detector AWST-6000 also detect outside motion through double-layer windows? This would prevent easy sabotage to the motion detector.
- According to the description, with dimmer module AWMR-210 the existing wall-switch can still be used. But does the remote function always override the wall-switch should it be off? And does the wall-switch override the remote function should that be off? And if the remote sets the light on, can you put it off by operating the wall-switch on and off?
Thanks in advance for your help!
Rob
The Netherlands.
Rob
The Netherlands.
