I am working on a plugin to control a Velleman K8000 board. Till now everything went fine but now i am stuck with creating devices in HS.
It's possible to define several devices within the plugin and they show up with an ON and OFF button on the status screen. I can added additional buttons with labels that i want however i can't get rid of the standard ON/OFF buttons.
Does anyone have a clue how to do this?
[SOLVED] Plugin and device buttons question
Moderator: Digit
Re: [SOLVED] Plugin and device buttons question
Note that this will device type is not supported by the HSTouch toggle option.
Thanks for letting me know.
Do you an altenative btw?
No I do not know an alternative. The HSTouch toggle option seems to only support devices created with the default io type.
