http://www.verkoop.licht-geluid.nl/Prod ... id=WW20177
73 euro's.. this could be a nice thing to try out some things with dmx right? Since all the other things are expensive. I rather try and play with some stuff before i buy the more expensive ones.
Led strip
Moderator: Mversluis
Led strip
you would still need to buy a 3 channel 24V PWM DMX dimmer, a 24V power supply and special cables with these 4 pin connectors....
so a EUR 16.50 12V ledstrip for testing is cheaper :
http://www.thewillows.nl/web2shop/?page ... tegory_id=
(you would still need to have a 12V power supply and a 3 channel DMX dimmer and of course a DMX controller)
Marcel
Marcel
- Snelvuur
Led strip
For some odd reason, i think i need to read up more about this stuff.. i should get the lanbox in my postbox about now i think. That will be the dmx controller (Controlling up to 512 DMX channels)
Do i still need the dimmer then? My idea was to just have some dmx devices , give it power and then plug it into my dmx controller.. sometimes i think to easy it seems.
Led strip
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"> My idea was to just have some dmx devices , give it power and then plug it into my dmx controller.. <hr height="1" noshade id="quote"></font id="quote"></blockquote id="quote">that is completely correct, the problem is : the led bar that you mention above is NOT a dmx device, it's just a bunch of leds that light up if you put 24V on it [:D]
Marcel
Marcel
Led strip
<br />So no dimmer is required for me? If i choose the bar you suggested.
yes, you still need a dimmer in both cases.
the only difference between the two led bars is that :
yours is more professional, bigger, brighter, has mounting brackets, more expensive etc.
yours is 24V, the other one is 12V
(compare specs : current/voltage/number of leds/length/brightness)
Any way to see in a fast view if a dmx is a "true" dmx?
in the description of your led bar is mentioned
"Wordt aangestuurd door LED MANAGER (DMX LED-voeding) "
that is a PWM DMX dimmer....
here's another PWM DMX dimmer (6 channels) :
optional accessories :
for easy mounting :
if you want a lot of leds, be careful about maximum current/voltage for your 12/24V power supply and PWM dimmer hardware...
Marcel
for easy mounting :
Marcel
