About 13 years ago is started with a self learning, voice controlled home automation system.
While very pleased with it in the beginning the system is now showing it's downside.
When i started with this system i could just say something like this "Please could you turn on the television and switch it to the Discovery channel' and it just happened. If is ask the same question today it won't even respond. It just stays at The Bold and th Beautiful or what ever is on.
The only way i can get it to respond is to use a command like ' Please Dear! Put on Discovery Channel and you can get that 144th pair of shoes!"
Posted just for no reason. I am happely married
Self learning HA system is getting to smart
Re: Self learning HA system is getting to smart
This post made me smile.
did you try to replace the batteries ?
i do recall they do that some times when the batteries get low
It could also be caused by a memory leak
Replacing the batteries makes the system even less responsive...
Actually it would be a money leak in this case.It could also be caused by a memory leak
time to upgrade the firmware ?
That's not possible either. It's the last model of the serie and no upgrades available.time to upgrade the firmware ?
Besides that i am quiet fond of this one.
I would sell it or destroy it before it's to late.
Alexander
