Hi there, what com port settings does everyone use for the 868 USB Visonic receiver?
Mine seems to be getting spammed by loads of data which is making it unusabled in RFReceiver, which includes mention of Digimax and ATI Devices which I dont have !! So I must have it configured incorrectly
thanks
Laser
Visionic - Port Settings
- Starting Member
Hi Laser
If you are receiving data then the Comport will be the right one!
Did you try Visonic variable?
- Starting Member
there is so much data, the application is not responsive. So I cant change anything
Did you click the "Toggle Baudrate button"? if so check the manual on that.
restart everything and disable directly all RF except Visonic.
I had that to, last weekend (RFReceiver not responding).
RFReceiver sometimes has a hard time keeping up with the data it receives. Last weekend i received >30.000 KAKU packets per hour (probably a doorbell from some neighbour that was pushed and got stuck) and RFReceiver just could not handle that.
But that was not with a Visonic receiver...
Maybe sharing some data you receive will help us help you.
