Control of my couch
Posted: Sun Oct 02, 2011 9:55 pm
by abl
At the moment I'm negotiating to buy a new couch. This couch can be electronically controlled to shift the seats forward and backward. Becoming a nerd more and more ( :D ) I would like to integrate a Merten z-wave switch (jalousie steuerung) to be able to control this via Homeseer.
My question is whether this would be possible (seems to me it is) and what would need to be done to control this? What should I ask the producer? Adding some additional wires)?
Re: Control of my couch
Posted: Sat Oct 08, 2011 10:12 pm
by ralhop
I think when you use an linair actuator that is connected to a jalousie controller it must work.
Posted: Sun Oct 09, 2011 12:14 am
by Henk
Do you have a link with more information of this special furniture ?
/Henk
Posted: Sun Oct 09, 2011 12:14 pm
by abl
Yesterday I received a PDF-document (4mb).
http://files.domoticaforum.eu/index.php ... anuals/Div
Posted: Sun Oct 09, 2011 10:03 pm
by ralhop
Do you want to use the touch switches too? I don't know if the controller accept if the wires are chorted together to move the actuator, mostly touch padles work on resistand. If then i prefer to take a sepperate 24v ( if the actuator is 24v) trafo and put the jalousie switch between the trafo and the actuator.
Posted: Thu Nov 03, 2011 11:09 pm
by abl
Sorry for my late reply. Yes I would like to use the touch switches too. I'm a layman on electronics (at least wiring). If I use a separate 24v trafo, how should I connect this to the actuator?
