Marmitek new CM15 computer interface
Posted: Thu Jan 10, 2008 2:54 pm
http://www.marmitek.com/en/catalogus/su ... ubgroep=83 English
http://www.marmitek.com/nl/catalogus/su ... ubgroep=83 Dutch
- With new activeHomePro software!
- This is the Pro-version of the CM11.
More programming possibilities because of conditional macros. For instance; the simulation of presence is executed only when your alarm is activated.
- More memory; possibility to use approximately 1.400 macros/timers.
- Ready built X-10 RF transmitter and X-10 transceiver (like the TM13) for specific or all home codes.
- User friendly software for beginners, with numerous extension possibilities for the experienced X-10 user.
- Software in English.
- Can be placed out of sight because of the supplied 1 metre power cord.
- See table for similarities and differences CM11 - CM15Pro.
- See www.activehomepro.eu for more information and free updates!
Signals used
With extras like extended codes, conditional macros and a built in transceiver, this product offers the functionality of a computer interface and a transceiver in one. In combination with the CM15Pro you only need receivers in order to control your lighting and equipment. With your computer you can program whatever you like. Switching on your lights at set or varying times (intelligent presence simulation), creating a home movie theatre, switching your outside lighting or having a fresh pot of coffee ready when you are woken up by the atmospheric lighting in your bedroom. Once everything is set according to your wishes, you can enter this into the memory of the CM15Pro and turn off your computer. You can also pre-set the CM15Pro for use in another house.
Signals used
