tapatalk to facilitate forum reading on iphone
Moderator: TheHogNL
Re: tapatalk to facilitate forum reading on iphone
The registration don't seem to be completed.
"Click 'Add my forum to Tapatalk Network' at the bottom of this page for new forum activation."
http://www.tapatalk.com/activate_tapata ... ugin=phpbb
So, even if the plugin is availiable we can't access the forum.
//Markus
Hi Markus
Done, please check again...
thank you! for testing
Thanks for adding tapatalk suportBwired wrote:Could somebody check if Tapatalk is working on this forum, just installed it.
thanks
Verstuurd van mijn ASUS Transformer Pad TF300T met Tapatalk
- Jeroen Bartels
I use safari on ipad to check this forum. Now i get a tapatalk message at every single page. Before this was not the case. What do I do to stop this.
**Jeroen**
Are there some specific reason that you don't want to use the (free) app instead of Safari?
(But either way, you *should* only get that message once for each time you visit the forum. Do you have any paranoid cookie settings or an anonymizing gateway?)
//Markus
Since today i have this problem to. I like the forum on iPad better without app.
groeten,
Had same problem on ipad and iphone, but only on ios 6.1.3. After I updated both to ios7 the tapatalk message was gone on every click.
Let me check, the forum has moved to a new server last week.
Should not be the reason...strange
Working ok here on Tapa
- Jeroen Bartels
I have 2 ipads. One ios 7 and one ios 6. Both same problem. Asking for Tapatalk on every click
**Jeroen**
I also noticed that since the move, domoticaforum.eu does not work for me anymore. www.domoticaforum.eu works though.
I am experiencing exactly the same issue. I thought the whole forum was down for several days until by chance I discovered this change. I wonder how many more people can not re-find the forum?I also noticed that since the move, domoticaforum.eu does not work for me anymore. www.domoticaforum.eu works though
should be solved now
domoticaforum.eu without the www is working now also
