Hello ,
I have a aeon z-stick and domotiga running on ubuntu
I plan to buy a zwave thermostat
Anyone know if horstmann HOR_AS2RF or HOR_HRT4-ZW-SET work with domotiga ?
Thanks
HOR_AS2RF or HOR_HRT4-ZW-SET with domotiga
Moderator: RDNZL
- Aqua-Passion
- Starting Member
Re: HOR_AS2RF or HOR_HRT4-ZW-SET with domotiga
I know a very good site about domotiga, let me link you to that site: http://domotiga.nl/
Here's information about the current tested zwave support http://domotiga.nl/projects/domotiga/wiki/Z-Wave
For me, I use the aeon stick and a fibaro switch.
The switch only works for 50% right now, because domotiga talks in basic zwave mode to the device so it can't address the mutli instance as it seems.
As for the thermostat, i don't think anybody has that tested in Domotiga just yet.
ELV FHT80b heating system.
- Aqua-Passion
- Starting Member
Hello ,
thanks
The "Tested Hardware" list is very short at this time
Do you know if domotiga is planned to work with zwave multi instance in futur ?
thanks
- RDNZL
The list contains 'all' the Z-Wave hardware I own and tested with personally.
I know almost two hands full of people starting to use DomotiGa with their specific Z-Wave hardware, and some work right away, others need more work, both from the users sending me debug logs, info, datasheets, sharing their experiences, and for me making it work with open-zwave and DomotiGa.
The problem is that Z-Wave is closed, of course there are projects like open-zwave which DomotiGa uses, but even they don't support all Z-Wave hardware yet. Same applies for HomeSeer.
I'm trying to get some money together to buy the newer Fibaro stuff, so I can code support for it, but there are alot of things to buy on my list
Z-Wave thermostats don't work without putting some effort in it, but some will work in the future, I promise..
Regards, Ron.
Hey Ron,
As you know I've got an aeon-stick S2 like you do and I have the Fibaro 2*1,5KW switch which needs the new stuff coded for it. THe fibaro dimmer and the single switch don't need the advanced code to my knowledge.. although I don't own them, so I can't exactly speak up for that. I only know that the fibaro FGS221 is the one single device that needs multi-instance support to be recognized as 2 different devices so you can switch both channels inside the device.
I'd like to extend to you a login on my box. I can set you up in a domotiga environment giving you access to the specific USB port and the domotiga setup so you can test directly onto the devices without having to digg deep into your wallet to buy these somewhat expensive devices (€ 60,- per device).
Jelle
Jelle
- Aqua-Passion
- Starting Member
Thank you , if i buy thermostat
I hope I can help you
It may be possible that I install a test server also and give you access if you are interested
- RDNZL
I'm ready to add thermostat support, let me know if you still planning to buy the thermostat.
Regards, Ron.
