Full control over TV via RS232?
DJF3
Post by DJF3 »
While looking for a TV in de bedroom I ran into a model with an RS232 port.
(LG 32LV2500 lg.com/nl/tv-audio-video/televisie/LG-l ... LV2500.jsp)
(manual: lg.com/nl/common/product/support.jsp?lo ... V2500.jsp#)
Page 110
This port can be used to connect to an external control device (like PC). What can be controlled?
Screenshot of LG TV RS232 commands
Screen Shot 2012-01-25 at 10.19.57 .png (107.66 KiB) Viewed 16709 times
This looks pretty cool.
So the Question remaining: (not that important)
WHY do I want to control remotely on a TV in my bedroom????? I need it but don't understand why ;-)
Help me..
DJ
Esteban
Re: Full control over TV via RS232?
Post by Esteban »
For the 'why', how about: So you can have it turn on in the morning when waking up? I know it's not much, but you have to legitimate it somehow, don't you? :P
Bjochems
Post by Bjochems »
You can get a fully automatic live stream of your living room when somebody is breaking into your house :-)
Bas
You can create a Homeseer event (not triggered by motion of course, but by a microphone that detects the snoring :lol: ) that will turn off the TV after you fall asleep.
DJF3
Post by DJF3 »
<grin>
structor
Post by structor »
DJF3 wrote: WHY do I want to control remotely on a TV in my bedroom????? I need it but don't understand why ;-)
Easy, because you can, therefor you must :D
Noel
Post by Noel »
When your wife and you are making "special" moves (up/down), turn TV on and change to "preset" TV channel.
labium
Post by labium »
why , do you want domotica ? It is all in the mind, i think you want to take control. controlfreak ? OCS ?
the human why is not logical , has never been, will never be . we arent computers, nor machines, we feel, react by motivation not by buttonpress.
DJF3
Post by DJF3 »
I got the TV ;-)
Do you know if there are HS plugins that can read/interpret serial data? Once the data is in HS I can write something to translate the data into readable info.
DJ
Droezel
Post by Droezel »
Here's my script to control my sharp aquos tv in the bedroom:
Sub Main(parm)
	'add spaces if neccesairy
	Do Until len(parm) = 8
		parm = parm & " "
	Loop
	Dim retVal
    	'hs.WriteLog "SharpTV", "Execute: [" + parm + "]"
	hs.SendToComPort 14, parm + vbCr
	hs.WaitSecs(1)
	retVal = hs.GetComPortData(14)
	'hs.WriteLog "SharpTV", "Response: [" + retVal + "]"
End Sub
Sub GetStatus()
	' get the power state and update device V7
	retVal = ""
	hs.SendToComPort 14, "POWR?   " + vbCr
	hs.WaitSecs(1)
	retVal = Trim(hs.GetComPortData(14))
	If Instr(retVal, "1") > 0 Then
		hs.SetDeviceStatus "V40", 2
	Else
		hs.SetDeviceStatus "V40", 3
	End If
	' update other devices, if powerstate is on, otherwise set all to off
	If hs.IsOn("V40") Then
		' get the audio state and update device V8
		retVal = ""
		hs.SendToComPort 14, "MUTE?   " + vbCr
		hs.WaitSecs(1)
		'hs.WriteLog "SharpTV", retVal
			hs.SetDeviceStatus "V41", 3
		Else
			hs.SetDeviceStatus "V41", 2
		End If
		'get the source input and update device V9, V10,V11
		'retVal = ""
		'hs.SendToComPort 14, "IAVD?   " + vbCr
		'hs.WaitSecs(1)
		'retVal = Trim(hs.GetComPortData(14))
		'If Instr(retval, "1") > 0 Then
		'	hs.SetDeviceStatus "V9", 2
		'Else
		'	hs.SetDeviceStatus "V9", 3
		'End If
		'If Instr(retval, "5") > 0 Then
		'	hs.SetDeviceStatus "V10", 2
		'Else
		'	hs.SetDeviceStatus "V10", 3
		'End If
		'If Instr(retval, "8") > 0 Then
		'	hs.SetDeviceStatus "V11", 2
		'Else
		'	hs.SetDeviceStatus "V11", 3
		'End If
		'get volume level
		retVal = ""
		hs.SendToComPort 14, "VOLM?   " + vbCr
		hs.WaitSecs(1)
		hs.SetDeviceValue "V42", Clng(retVal)
		hs.SetDeviceString "V42", retVal
		'hs.SetDeviceString "V12", ""
		'get sleep timer
		hs.SendToComPort 14, "OFTM?   " + vbCr
		hs.WaitSecs(1)
		'hs.WriteLog "SharpTV", "Sleeptimer: [" & retVal & "]"
		hs.SetDeviceValue "V43", Clng(retVal)
		If retVal = 0 Then
			hs.SetDeviceString "V43", "Off"
		Else
			hs.SetDeviceString "V43", retVal & " min"
		End If
		'get the channel
		hs.SendToComPort 14, "DCCH?   " + vbCr
		hs.WaitSecs(1)
		'hs.WriteLog "SharpTV", "Channel: [" & retVal & "]"
		hs.SetDeviceValue "V44", Clng(retVal)
		hs.SetDeviceString "V44", retVal
	Else
		' set all other devices to off
		hs.SetDeviceValue "V43", 0
	End If
	'hs.CloseComPort 10
End Sub
Sub PowerToggle()
		hs.SendToComPort 14, "POWR0   " + vbCr
	Else
		hs.SendToComPort 14, "POWR1   " + vbCr
	End If
End Sub
Sub SetVolume()
	Volume = Cstr(hs.DeviceValue("V42"))
	If len(Volume) = 1 Then
		Volume = "0" + Volume + "  "
	Else
		Volume = Volume + "  "
	End If
	hs.SetDeviceString "V42", Volume
	hs.SendToComPort 14, "VOLM" + Volume + vbCr
End Sub
And here's a screenshot of some tv events, I have 2 sharp aquos tv's in the house.
aagesen
Re:
Post by aagesen »
DJF3 wrote:I got the TV ;-)
DJ
Hi, take a look at this thread http://board.homeseer.com/showthread.php?t=123350
DJF3
Post by DJF3 »
Fantastic!
Droezel, thank you for sharing and aagesen, thank you for this link..
Just have to figure out what exactly I'm going to do with ;-)
DJ
aagesen
Post by aagesen »
And now there is a plugin too.
I'm markus on the homeseer forum so I'm the one bothering mrhappy. This works with my lg tv from 2009.
http://board.homeseer.com/showthread.php?t=152929
