Your Bwired porch Dome camera
I guess basically what you're saying is: why don't machines have the same intelligence as us, humans?
And what you're looking for, is an automation system with a plug into your brain, so it can read your mind and whisper things into your ear. We are just not there yet... :-)
bwkevin
Post by bwkevin »
Yes Digit, I guess the ultimate answer would be to have a human assistant!
Snelvuur
Post by Snelvuur »
So basicly he's saying he wants to get married.
l0rien
Post by l0rien »
Now we're talking ;-)
I am a 'techie', but just not a hardware techie. My work is actually looking into getting more intelligence into simulations for use in training. And like you say bwkevin, we still have a very long way to come. There is some very cool stuff going on, but those things are mostly specific for one single purpose, like one task for one situation in a game/simulation.
To be able to do the things you (and I) would like, the system needs to have a model of the user. Know what its needs are at any one point in time. That is so terribly complex that I'm not out of work for the next 50+ years ;-)
Luckily, current computing power makes relatively simple things like facial recognition are fairly easy to do, provided you have a clear picture of the person. And for that I need to know which camera can provide that in various weather and lighting conditions.
Ok; so you have a good camera and you can identify who you (the system, that is) are dealing with. What will that help you? Next comes tracing where the user is going, what he/she is doing and particularly, <b>why</b>. Why do i sometimes keep my working clothes on when i come home in the evening? The system will never know; till the day i'll be "plugged in"..
Neo.[:o)]
Blue pill or Red pill [:)]
bwkevin
Post by bwkevin »
Getting back to porch cameras :-), I agree with IOrien and Digit that more sophistication is needed. I like the neural intelligence concept that iOmniscient (http://www.iomniscient.com/products.htm) provide. Their software is more useful than just a braindead camera and probably could be applied to a home security situation too.
However, at a lesser cost (zero) I'm starting to get creative with the porch cam and saving a lot of wasted time. Because since I installed it I would spend about 5-10 mins a day reviewing the last 24 hours of activity. It uses motion dection which only records 5 secs before and after movement, but even at the maximum 3x review speed that turned out to be quite time-consuming.
The breakthrough came over the last few days when I've discovered 90% of activity comes from our 2 cats on that camera. What a great life they lead on my porch! Even asleep, a slight twitch of a tail is enough to roll the camera for another 10 seconds.
So I reset the motion sensor boxes to exclude everything at cat height and their wander path, and so removed most of the useless activity.
The human brain triumphs again - and without pills, Pieter! :-)
Yes there are motion sensors which only register movements above the X kilo. You can also examine the movement in the image itself by X percentage pixel movement. I do that with my Mobotix camera as well http://www.bwired.nl/Cammobotix.asp with good result.
Pieter
JMeredith
Post by JMeredith »
I have an Axis 2120 on my front porch and I am curious how to get the last x images after it senses motion. I have the motion alarm set up to capture 2 pre-alarm images every 2 seconds and 3 post-alarm images every 2 seconds... but how do you always show the last 5 images on your website?
great projects by the way!!
I am slowly getting there, I have a sensatronics u16 at home which I am using to get inside, outside, and hottub temps... garage doors open/close...driveway and living room motion, and water level in the cat's water bowl.
currently Im just watching real time XML feed, I really want to get it into a database to start looking at trends...
thanks,
-J
HI
Check the Axis API at:
http://www.axis.com/techsup/cam_servers ... _index.php
Example 1: Create an image buffer, named DOOR1, with 10 pre-alarm images and 15 post-alarm images.
http://myserver/axis-cgi/buffer/command.cgi?do=start&buffername=DOOR1&prealarm=10&postalarm=15&uri=ftp://jpg/1/image.jpg
Example 2: Stop a buffer.
http://myserver/axis-cgi/buffer/command.cgi?do=stop&buffername=DOOR1
Example 3: Get images from the buffer.
http://myserver/axis-cgi/buffer/command.cgi?do=get&buffername=DOOR1&index=1
Example 4: Create an image buffer, named DOOR2. The images should be taken from camera 1 and have a resolution of 320x240 pixels. Five post-alarm images should be stored.
http://myserver/axis-cgi/buffer/command.cgi?do=start&buffername=DOOR2
&postalarm=5&uri=ftp://jpg/image.jpg?resolution=320x240&camera=1
JMeredith
Post by JMeredith »
Pieter,
that API would be great but I am running v2.32 firmware and the API isnt supported :(
there are manual settings for the pre & post alarm buffer... that part is working fine. I get 5 files sent to FTP on every alarm...
so after a week of in & out traffic I will likey have hundreds of images saved to the FTP directory I would like to be able to see only the LAST 5 that were sent...
should I try to write some ASP script that will look at the filenames (which contain the date and time) or is there a better way?
are you storing images in a folder only, or are you linking to them via a database? how much "history" do you keep? we use the frontdoor 20 times a day so I could quickly get thousands of images...
-J
We just talk about is in this topic below
http://www.domoticaforum.eu/topic.asp?TOPIC_ID=4016
and check this asp sample, with some tuning it can be done.
http://www.asp101.com/articles/john/ima ... efault.asp
are you sure no API?
check this for firmware 2.x
http://www.axis.com/techsup/cam_servers ... tp_api.php
Return to “Bwired Forum”
