Powerlink serial pinout, linux daemon and web interface
Moderators: Rene, Willem4ever
Re: Powerlink serial pinout
not really a "conflict" but the fact that you went out of memory while installing package
It's seems probable.
I do receive my new MR3020 on saturday.
Today I try to use my serial/USB converter (http://cgi.ebay.fr/USB-to-Serial-Adapte ... 415d279d2b) with Powermax remote programmer software and pins like write VIKNET but the software doen't reconise my alarm.
It's seems that I do connect to the dual RS232 pins but I can't found GND pin; I see that but I don't know if it is OK
http://www.domoticaforum.eu/viewtopic.p ... 4&start=15
I don't understand but i need some information; you have a powermax+ or a powermax pro ?
why are you commenting about another picture see my picture at the beginning of the topic or attach a picture of your wiring (mail if required) I did put all information including where to get power, GND tx and rx remember that you have to wire tx from alarm to rx from usb ttl
did you install the serial driver:
you also have to edit /etc/pmaxd.conf
opkg update
opkg install kmod-usb-serial-pl2303
Today I received my new MR3020 (three days from AMAZ...) that's nice
Well tomorrow I will rebegin to install all the system.
I do install:
1) openwrt for MR 3020
2) lighttpd
3) xpl library
4) xpl examples and utilities (if I want)
5) pmax deamon
6) serial driver
Anything else?
I do install:
2) lighttpd
3) xpl library
5) pmax deamon
6) serial driver
Anything else?
libconfig is used, (but you noticed it)
avoid installing pmaxd at first and do some sanity check before:
with the router unplugged from the alarm:
install screen (remove it once finished to avoid taking too much memory)
test your usb TTL serial adapter,
then type something on the keyboard: --> nothing display on your screen
then connect RX and TX of your dongle together (not to the alarm) and retype something : --> whatever you type is written on screen
if yes: your serial dongle is working, if not do not try to go further.
Then connect to your alarm, launch screen and try to enroll the pmax (see your pmax doc): you should see some garbage on the screen
if yes remove screen and install the pmax daemon
edit /etc/init.d/pmaxd and remove the two line "testpmaxd" this daemon reboot the router if it see no answer from pmax
kill testpmaxd if required (it wait some minutes after a reboot before trying a reboot)
modify /etc/pmaxd.conf
verify pmaxd is not running
type
screen /dev/ttyusbX 9600
type
/bin/pmaxd -fvvvvvvvvvv
All was OK since to test RS232/serial dongle.
I have only 68Kb free and Screen is 142Kb hight
I am looking for an other solution for testing but I don't find
list of my installed package, everything not here can probably be removed,
removed everything xpl based for testing the serial you don't need them
opkg list-installed
base-files - 107-r31650
base-files-network - 4
busybox - 1.19.4-1
dnsmasq - 2.59-3
dropbear - 2011.54-2
firewall - 2-49
hotplug2 - 1.0-beta-4
iptables - 1.4.10-4
iw - 3.3-1
kmod-ath9k - 3.3.5+2012-04-17-2
kmod-crypto-aes - 3.3.5-1
kmod-crypto-core - 3.3.5-1
kmod-gpio-button-hotplug - 3.3.5-1
kmod-ipt-conntrack - 3.3.5-1
kmod-leds-gpio - 3.3.5-1
kmod-ledtrig-timer - 3.3.5-1
kmod-ledtrig-usbdev - 3.3.5-1
kmod-lib-crc-ccitt - 3.3.5-1
kmod-mac80211 - 3.3.5+2012-04-17-2
kmod-pppoe - 3.3.5-1
kmod-usb-core - 3.3.5-1
kmod-usb-ohci - 3.3.5-1
kmod-usb-serial - 3.3.5-1
kmod-usb-serial-pl2303 - 3.3.5-1
kmod-usb2 - 3.3.5-1
libc - 0.9.33-107
libconfig - 1.4.8-2
libgcc - 4.6-linaro-107
libip4tc - 1.4.10-4
libpcre - 8.11-2
libpthread - 0.9.33-107
libuci - 2012-03-28.1-1
libxpl - 1
lighttpd - 1.4.30-2
lighttpd-mod-cgi - 1.4.30-2
mtd - 17
opkg - 618-2
pmaxd - 1
swconfig - 10
uboot-envtools - 2011.06-4
wpad-mini - 20120428-1
xPLLibexample - 1
I compare my list of packages with yours; I have the double.
So I kill / remove a lot of them but my mr3020 doesn't was out of order; I think I delete a file that was useful.
Today I restart just on Tenet (192.168.1.1) and I am coming on the front page of OpenWRT; I was reassured.
Now, can I reinstall original TP Link firmware or reinstall OpenWRT?
Later I will install package by package, comparing with your list.
Thanks for your patience with me
probably one of the following :
http://wiki.openwrt.org/doc/howto/generic.failsafe
in your case probably :
rm -r /overlay/*
reboot -f
but check the whole page first
please send me the output of the "df"command
mine is:
rm -r /overlay/*
reboot -f
mine is:
root@OpenWrt:~# df
Filesystem 1K-blocks Used Available Use% Mounted on
rootfs 1472 1312 160 89% /
/dev/root 1536 1536 0 100% /rom
tmpfs 14588 68 14520 0% /tmp
tmpfs 512 0 512 0% /dev
/dev/mtdblock3 1472 1312 160 89% /overlay
overlayfs:/overlay 1472 1312 160 89% /
root@OpenWrt:~#
This is my answer:
root@(none):/# df
rootfs 1536 1536 0 100% /
tmpfs 14580 16 14564 0% /tmp
root@(none):/#
I am longer from you
root@(none):/# df
root@(none):/#
where did you get the original openwrt image, mine is from
http://wiki.openwrt.org/toh/tp-link/tl-wr703n
find "squashfs-factory.bin" in the page
I think yours is a bit different or I missed something,
you can also send me a screenshot when you connect using ssh, to check your version, I will send you my screenshot once I get back home
Mine is this:
openwrt-ar71xx-generic-tl-mr3020-v1-squashfs-factory.bin
the great difference (I haven't /dev/mtdblock3 )comes because I have deleted wrong files
Now I can't connect by ssh because I have deleted files with my password ( see first and last line: "root@(none) )
for information when sshing I get :
but I am afraid I can't help you more, try sorting your issues with openwrt first, then retry installing pmaxd
BusyBox v1.19.4 (2012-05-08 19:59:09 MST) built-in shell (ash)
Enter 'help' for a list of built-in commands.
_______ ________ __
| |.-----.-----.-----.| | | |.----.| |_
| - || _ | -__| || | | || _|| _|
|_______|| __|_____|__|__||________||__| |____|
|__| W I R E L E S S F R E E D O M
ATTITUDE ADJUSTMENT (Bleeding Edge, r31650)
* 1/4 oz Vodka Pour all ingredients into mixing
* 1/4 oz Gin tin with ice, strain into glass.
* 1/4 oz Amaretto
* 1/4 oz Triple sec
* 1/4 oz Peach schnapps
* 1/4 oz Sour mix
* 1 splash Cranberry juice
by the way try telneting instead of sshing remember that ssh is not enable at first start and until you change your password
