Cannot find dynamic library 'libdomozwave.so': libdomozwave.
Posted: Wed Mar 21, 2012 5:01 pm
by christiand
I am trying to get the hang on Linux but am not very familiar with the locations and procedures. I have managed to get ubuntu 11.10 working in a VM with a Aeon Labs Z-wave Stick 2. I got Domotiga installed (thanks to the good procedures on domotiga.nl) and the z-wave stick configured. In the Z-Wave Commander i can see my devices i included but when I try to do an action like on/off on it I get this error and the application crashed.
[60] Cannot find dynamic library 'libdomozwave.so': libdomozwave.so: cannot open shared object file: No such file or directory. CZWave.SetValue.1412
[b]Log at startup:[/b]
2012/03/21 15:53:05 ---- Program Restart ----
2012/03/21 15:53:05 Starting DomotiGa V0.1.204 last updated on 2012-03-21 at 09:15:46
2012/03/21 15:53:05 Running on host 'IENIEMINIE' (pid 3349) as user 'christian' (id 1000) with language en_US.UTF-8
2012/03/21 15:53:05 Program base directory is '/home/christian/domotiga'.
2012/03/21 15:53:05 Database settings are loaded from 'domotiga.conf'.
2012/03/21 15:53:05 Active logfiles are 'main-2012-03.log', 'speak-2012-03.log' and 'debug-2012-03.log'.
2012/03/21 15:53:05 Running on Gambas version 2.23.1
2012/03/21 15:53:05 Server uptime is 15:53:05 up 49 min, 1 user, load average: 0.91, 0.28, 0.14
2012/03/21 15:53:05 This DomotiGa instance is running in server mode.
2012/03/21 15:53:05 Starting setup ...
2012/03/21 15:53:05 NOTE: All disabled module log entries are muted, enable main debug if you want to see them!
2012/03/21 15:53:05 XML-RPC server listening on Port 9009
2012/03/21 15:53:05 UDP Broadcasts are enabled on Port 19009
2012/03/21 15:53:05 Server Statistics enabled.
2012/03/21 15:53:05 Z-Wave support enabled.
2012/03/21 15:53:05 Z-Wave interface connected to Port /dev/ttyUSB0
2012/03/21 15:53:05 Running Z-Wave API version 2.78 and ZDK version 5.02 Patch 3
2012/03/21 15:53:05 Z-Wave Home ID is 014D0051
2012/03/21 15:53:07 Done with setup ...
2012/03/21 15:53:07 Entering main program loop.
2012/03/21 15:53:07 The Time of Day is afternoon.
2012/03/21 15:53:07 It's light outside.
2012/03/21 15:53:07 DomotiGa is running for 0 days, 0 hrs, 0 mins, and 0 secs.
2012/03/21 15:53:07 Successfully set 'NextPlanning' to '00:00:00'.
2012/03/21 15:53:07 Latitude: 52.8167 Longitude: -5.7667 Timezone: 1
2012/03/21 15:53:07 Sunrise at 07:24, Sunset at 19:37
2012/03/21 15:53:07 Twilight Sunrise at 06:49, Twilight Sunset at 20:11 (civil)
2012/03/21 15:53:07 Moon phase is New.
2012/03/21 15:53:07 Moon is in Aquarius.
2012/03/21 15:53:07 Age from new 28 days.
2012/03/21 15:53:07 Distance 62.37 Earth radii.
2012/03/21 15:53:07 Ecliptic latitude: 5.08 degrees.
2012/03/21 15:53:07 Ecliptic longitude: 348.24 degrees.
2012/03/21 15:53:07 This is a leap year.
2012/03/21 15:53:07 Season is spring.
[b]Error log:[/b]
2012/03/21 15:21:49 Z-Wave support enabled.
2012/03/21 15:21:49 Z-Wave interface connected to Port /dev/ttyUSB0
2012/03/21 15:21:49 Z-Wave Error: Cannot find dynamic library 'libdomozwave.so': libdomozwave.so: cannot open shared object file: No such file or directory at CZWave.OZW_Init.1371
2012/03/21 15:22:03 Z-Wave Error: Cannot find dynamic library 'libdomozwave.so': libdomozwave.so: cannot open shared object file: No such file or directory
2012/03/21 15:22:03 Z-Wave support enabled.
2012/03/21 15:22:03 Z-Wave interface connected to Port /dev/ttyUSB0
2012/03/21 15:22:03 Running Z-Wave API version 2.78 and ZDK version 5.02 Patch 3
2012/03/21 15:22:03 Z-Wave Home ID is 014D0051
Re: Cannot find dynamic library 'libdomozwave.so': libdomozwave.
Posted: Wed Mar 21, 2012 6:59 pm
by j.hoekstra
Did you follow these
instructions as well?
And if you encounter and error about:
Manager::Get()->SetPollInterval( polltime);
follow this:
http://domotiga.nl/issues/95#note-25
It's a bit work to setup, but when it works, it's really nice
Posted: Fri Mar 23, 2012 12:13 am
by christiand
I did a full reinstall of Ubuntu and still got the error. Then after more carefull reading I noticed that I got the 410 revision of open-zwave. After using the 409 revision it is working wel. Now to find out how to import the devices from the aeon labs z-wave stick.
Posted: Fri Mar 23, 2012 2:17 am
by christiand
Ok finally got everything compiled and running. I can start the z-wave commander and see my devices. But when I try to place an action nothing happens. I tried putting the interface in native mode and open-zwave mode. When I activate debug in the interface selection in combination with open-zwave the application crashes as soon as I try an on/off or add action. Below is the logfile of open-zwave.
2012/03/23 01:06:06 [WebServer] HTTP connect from client with ip address 192.168.1.215 (192.168.1.215)
2012/03/23 01:07:26 [Z-Wave] > 15
2012/03/23 01:07:26 [Z-Wave] Get controller info
2012/03/23 01:07:26 [Z-Wave] > 01 03 00 15 E9
2012/03/23 01:07:26 [Z-Wave] < 06 - received ACK.
2012/03/23 01:07:26 [Z-Wave] SOF found
2012/03/23 01:07:26 [Z-Wave] Packet Length = 16
2012/03/23 01:07:26 [Z-Wave] < 01 10 01 15 5A 2D 57 61 76 65 20 32 2E 37 38 00 01 9B
2012/03/23 01:07:26 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:26 [Z-Wave] > 06
2012/03/23 01:07:26 [Z-Wave] Got response frame!
2012/03/23 01:07:26 [Z-Wave] API libary version: 2.78
2012/03/23 01:07:26 [Z-Wave] ZDK version: 5.02 Patch 3
2012/03/23 01:07:26 [Z-Wave] Get home & controller IDs
2012/03/23 01:07:26 [Z-Wave] > 01 03 00 20 DC
2012/03/23 01:07:26 [Z-Wave] Packet Length = 8
2012/03/23 01:07:26 [Z-Wave] < 01 08 01 20 01 4D 00 51 01 CA
2012/03/23 01:07:26 [Z-Wave] Home Id: 014D0051
2012/03/23 01:07:26 [Z-Wave] Controller node Id: 1
2012/03/23 01:07:26 [Z-Wave] Get capabilities
2012/03/23 01:07:26 [Z-Wave] > 01 03 00 07 FB
2012/03/23 01:07:26 [Z-Wave] Packet Length = 43
2012/03/23 01:07:26 [Z-Wave] < 01 2B 01 07 03 07 00 86 00 02 00 01 FE 80 FE 88 0F 00 00 00 FB 97 7F 82 07 00 00 80 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 C2
2012/03/23 01:07:26 [Z-Wave] TODO: Handle api get capabilities.
2012/03/23 01:07:26 [Z-Wave] Get SUC node ID
2012/03/23 01:07:26 [Z-Wave] > 01 03 00 56 AA
2012/03/23 01:07:26 [Z-Wave] < 01 04 01 56 01 AD
2012/03/23 01:07:26 [Z-Wave] SUC node Id: 1
2012/03/23 01:07:26 [Z-Wave] Get init data
2012/03/23 01:07:26 [Z-Wave] > 01 03 00 02 FE
2012/03/23 01:07:26 [Z-Wave] Packet Length = 37
2012/03/23 01:07:26 [Z-Wave] < 01 25 01 02 05 08 1D 3F 60 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 03 01 94
2012/03/23 01:07:26 [Z-Wave] Got init data result back.
2012/03/23 01:07:26 [Z-Wave] Controller Chip Type: 3 - ZW0301
2012/03/23 01:07:26 [Z-Wave] Controller Chip Revison: 01
2012/03/23 01:07:26 [Z-Wave] Getting node protocol info for node id 1
2012/03/23 01:07:26 [Z-Wave] > 01 04 00 41 01 BB
2012/03/23 01:07:26 [Z-Wave] Packet Length = 9
2012/03/23 01:07:26 [Z-Wave] < 01 09 01 41 92 16 00 02 02 01 33
2012/03/23 01:07:26 [Z-Wave] Received node protocol info for node id 1
2012/03/23 01:07:26 [Z-Wave] Listening node.
2012/03/23 01:07:26 [Z-Wave] Basic Type: Static Controller
2012/03/23 01:07:26 [Z-Wave] Generic Type: Static Controller
2012/03/23 01:07:26 [Z-Wave] Specific Type: 1
2012/03/23 01:07:26 [Z-Wave] Getting node protocol info for node id 2
2012/03/23 01:07:26 [Z-Wave] > 01 04 00 41 02 B8
2012/03/23 01:07:26 [Z-Wave] < 01 09 01 41 D2 9C 00 04 10 01 ED
2012/03/23 01:07:26 [Z-Wave] Received node protocol info for node id 2
2012/03/23 01:07:26 [Z-Wave] Optional functionality.
2012/03/23 01:07:26 [Z-Wave] Basic Type: Routing Slave
2012/03/23 01:07:26 [Z-Wave] Generic Type: Binary Switch
2012/03/23 01:07:26 [Z-Wave] Getting node protocol info for node id 3
2012/03/23 01:07:26 [Z-Wave] > 01 04 00 41 03 B9
2012/03/23 01:07:26 [Z-Wave] Received node protocol info for node id 3
2012/03/23 01:07:27 [Z-Wave] Getting node protocol info for node id 4
2012/03/23 01:07:27 [Z-Wave] > 01 04 00 41 04 BE
2012/03/23 01:07:27 [Z-Wave] < 06 - received ACK.
2012/03/23 01:07:27 [Z-Wave] SOF found
2012/03/23 01:07:27 [Z-Wave] Packet Length = 9
2012/03/23 01:07:27 [Z-Wave] < 01 09 01 41 D3 9C 00 04 11 01 ED
2012/03/23 01:07:27 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:27 [Z-Wave] > 06
2012/03/23 01:07:27 [Z-Wave] Got response frame!
2012/03/23 01:07:27 [Z-Wave] Received node protocol info for node id 4
2012/03/23 01:07:27 [Z-Wave] Listening node.
2012/03/23 01:07:27 [Z-Wave] Optional functionality.
2012/03/23 01:07:27 [Z-Wave] Basic Type: Routing Slave
2012/03/23 01:07:27 [Z-Wave] Generic Type: Multilevel Switch
2012/03/23 01:07:27 [Z-Wave] Specific Type: 1
2012/03/23 01:07:27 [Z-Wave] Getting node protocol info for node id 5
2012/03/23 01:07:27 [Z-Wave] > 01 04 00 41 05 BF
2012/03/23 01:07:27 [Z-Wave] < 01 09 01 41 D2 94 00 03 10 01 E2
2012/03/23 01:07:27 [Z-Wave] Received node protocol info for node id 5
2012/03/23 01:07:27 [Z-Wave] Basic Type: Slave
2012/03/23 01:07:27 [Z-Wave] Generic Type: Binary Switch
2012/03/23 01:07:27 [Z-Wave] Getting node protocol info for node id 6
2012/03/23 01:07:27 [Z-Wave] > 01 04 00 41 06 BC
2012/03/23 01:07:27 [Z-Wave] < 01 09 01 41 D2 9C 00 04 10 01 ED
2012/03/23 01:07:27 [Z-Wave] Received node protocol info for node id 6
2012/03/23 01:07:27 [Z-Wave] Getting node protocol info for node id 14
2012/03/23 01:07:27 [Z-Wave] > 01 04 00 41 0E B4
2012/03/23 01:07:27 [Z-Wave] < 01 09 01 41 12 96 00 01 01 01 33
2012/03/23 01:07:27 [Z-Wave] Received node protocol info for node id 14
2012/03/23 01:07:27 [Z-Wave] Sleeping node.
2012/03/23 01:07:27 [Z-Wave] Basic Type: Controller
2012/03/23 01:07:27 [Z-Wave] Generic Type: Generic Controller
2012/03/23 01:07:27 [Z-Wave] Getting node protocol info for node id 15
2012/03/23 01:07:27 [Z-Wave] > 01 04 00 41 0F B5
2012/03/23 01:07:27 [Z-Wave] Received node protocol info for node id 15
2012/03/23 01:07:27 [Z-Wave] Requesting manufacturer specific report for node id 2
2012/03/23 01:07:27 [Z-Wave] > 01 08 00 13 02 03 72 04 05 96
2012/03/23 01:07:27 [Z-Wave] Packet Length = 4
2012/03/23 01:07:27 [Z-Wave] < 01 04 01 13 01 E8
2012/03/23 01:07:27 [Z-Wave] data delivered to Z-Wave device.
2012/03/23 01:07:27 [Z-Wave] Packet Length = 5
2012/03/23 01:07:27 [Z-Wave] < 01 05 00 13 01 00 E8
2012/03/23 01:07:27 [Z-Wave] Got request frame!
2012/03/23 01:07:27 [Z-Wave] response with callback 1 received.
2012/03/23 01:07:27 [Z-Wave] Requesting capabilities for node id 2
2012/03/23 01:07:27 [Z-Wave] > 01 04 00 60 02 99
2012/03/23 01:07:27 [Z-Wave] < 01 04 01 60 01 9B
2012/03/23 01:07:27 [Z-Wave] TODO: Handle get node capabilities.
2012/03/23 01:07:27 [Z-Wave] Packet Length = 19
2012/03/23 01:07:27 [Z-Wave] < 01 13 00 49 84 02 0D 04 10 01 72 86 82 87 75 27 25 85 EF 26 F1
2012/03/23 01:07:27 [Z-Wave] Classes supported by node id 2 are:
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_MANUFACTURER_SPECIFIC
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_VERSION
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_HAIL
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_INDICATOR
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_PROTECTION
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_SWITCH_ALL
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_SWITCH_BINARY
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_ASSOCIATION
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_MARK
2012/03/23 01:07:27 [Z-Wave] COMMAND_CLASS_SWITCH_MULTILEVEL
2012/03/23 01:07:27 [Z-Wave] Node with id '2' not found in database!
2012/03/23 01:07:27 [Z-Wave] Requesting manufacturer specific report for node id 3
2012/03/23 01:07:27 [Z-Wave] > 01 08 00 13 03 03 72 04 05 97
2012/03/23 01:07:27 [Z-Wave] Packet Length = 14
2012/03/23 01:07:27 [Z-Wave] < 01 0E 00 04 02 03 08 72 05 00 64 20 01 00 00 CE
2012/03/23 01:07:27 [Z-Wave] Application command handler response with callback 2 received.
2012/03/23 01:07:27 [Z-Wave] Manufacturer Report response received.
2012/03/23 01:07:27 [Z-Wave] Node: 3
2012/03/23 01:07:27 [Z-Wave] Manufacturer: Popp/Duwi
2012/03/23 01:07:27 [Z-Wave] Model: Unknown (20 01)
2012/03/23 01:07:27 [Z-Wave] Requesting capabilities for node id 3
2012/03/23 01:07:27 [Z-Wave] > 01 04 00 60 03 98
2012/03/23 01:07:27 [Z-Wave] < 01 13 00 49 84 03 0D 04 10 01 72 86 82 87 75 27 25 85 EF 26 F0
2012/03/23 01:07:27 [Z-Wave] Classes supported by node id 3 are:
2012/03/23 01:07:27 [Z-Wave] Node with id '3' not found in database!
2012/03/23 01:07:28 [Z-Wave] Requesting manufacturer specific report for node id 4
2012/03/23 01:07:28 [Z-Wave] > 01 08 00 13 04 03 72 04 05 90
2012/03/23 01:07:28 [Z-Wave] < 06 - received ACK.
2012/03/23 01:07:28 [Z-Wave] SOF found
2012/03/23 01:07:28 [Z-Wave] Packet Length = 4
2012/03/23 01:07:28 [Z-Wave] < 01 04 01 13 01 E8
2012/03/23 01:07:28 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:28 [Z-Wave] > 06
2012/03/23 01:07:28 [Z-Wave] Got response frame!
2012/03/23 01:07:28 [Z-Wave] data delivered to Z-Wave device.
2012/03/23 01:07:28 [Z-Wave] Packet Length = 5
2012/03/23 01:07:28 [Z-Wave] < 01 05 00 13 01 00 E8
2012/03/23 01:07:28 [Z-Wave] Got request frame!
2012/03/23 01:07:28 [Z-Wave] response with callback 1 received.
2012/03/23 01:07:28 [Z-Wave] Requesting capabilities for node id 4
2012/03/23 01:07:28 [Z-Wave] > 01 04 00 60 04 9F
2012/03/23 01:07:28 [Z-Wave] < 01 04 01 60 01 9B
2012/03/23 01:07:28 [Z-Wave] TODO: Handle get node capabilities.
2012/03/23 01:07:28 [Z-Wave] Requesting manufacturer specific report for node id 5
2012/03/23 01:07:28 [Z-Wave] > 01 08 00 13 05 03 72 04 05 91
2012/03/23 01:07:28 [Z-Wave] Requesting capabilities for node id 5
2012/03/23 01:07:28 [Z-Wave] > 01 04 00 60 05 9E
2012/03/23 01:07:28 [Z-Wave] Requesting manufacturer specific report for node id 6
2012/03/23 01:07:28 [Z-Wave] > 01 08 00 13 06 03 72 04 05 92
2012/03/23 01:07:28 [Z-Wave] Requesting capabilities for node id 6
2012/03/23 01:07:28 [Z-Wave] > 01 04 00 60 06 9D
2012/03/23 01:07:28 [Z-Wave] CAN received.
2012/03/23 01:07:28 [Z-Wave] Requesting basic report for node id 255
2012/03/23 01:07:28 [Z-Wave] > 01 09 00 13 FF 02 20 02 05 18 27
2012/03/23 01:07:28 [Z-Wave] < 01 04 01 13 00 E9
2012/03/23 01:07:28 [Z-Wave] ERROR: data could not be delivered to Z-Wave device!
2012/03/23 01:07:52 [Z-Wave] Requesting basic report for node id 2
2012/03/23 01:07:52 [Z-Wave] > 01 09 00 13 02 02 20 02 05 19 DB
2012/03/23 01:07:52 [Z-Wave] SOF found
2012/03/23 01:07:52 [Z-Wave] Packet Length = 6
2012/03/23 01:07:52 [Z-Wave] < 01 06 00 49 81 00 00 31
2012/03/23 01:07:52 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:52 [Z-Wave] > 06
2012/03/23 01:07:52 [Z-Wave] Got request frame!
2012/03/23 01:07:52 [Z-Wave] Classes supported by node id 0 are:
2012/03/23 01:07:52 [Z-Wave] Node with id '0' not found in database!
2012/03/23 01:07:52 [Z-Wave] Packet Length = 5
2012/03/23 01:07:52 [Z-Wave] < 01 05 00 13 18 00 F1
2012/03/23 01:07:52 [Z-Wave] response with callback 24 received.
2012/03/23 01:07:52 [Z-Wave] Packet Length = 14
2012/03/23 01:07:52 [Z-Wave] < 01 0E 00 04 00 06 08 32 02 21 12 00 00 00 00 F8
2012/03/23 01:07:52 [Z-Wave] Application command handler response with callback 0 received.
2012/03/23 01:07:52 [Z-Wave] Got unsupported FUNC_ID_APPLICATION_COMMAND_HANDLER type: 32, ignoring
2012/03/23 01:07:52 [Z-Wave] CAN received.
2012/03/23 01:07:54 [Z-Wave] Requesting basic report for node id 3
2012/03/23 01:07:54 [Z-Wave] > 01 09 00 13 03 02 20 02 05 1A D9
2012/03/23 01:07:54 [Z-Wave] < 06 - received ACK.
2012/03/23 01:07:54 [Z-Wave] SOF found
2012/03/23 01:07:54 [Z-Wave] Packet Length = 4
2012/03/23 01:07:54 [Z-Wave] < 01 04 01 13 01 E8
2012/03/23 01:07:54 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:54 [Z-Wave] > 06
2012/03/23 01:07:54 [Z-Wave] Got response frame!
2012/03/23 01:07:54 [Z-Wave] data delivered to Z-Wave device.
2012/03/23 01:07:54 [Z-Wave] Packet Length = 5
2012/03/23 01:07:54 [Z-Wave] < 01 05 00 13 1A 00 F3
2012/03/23 01:07:54 [Z-Wave] Got request frame!
2012/03/23 01:07:54 [Z-Wave] response with callback 26 received.
2012/03/23 01:07:54 [Z-Wave] Packet Length = 9
2012/03/23 01:07:54 [Z-Wave] < 01 09 00 04 00 03 03 20 03 00 D1
2012/03/23 01:07:54 [Z-Wave] Application command handler response with callback 0 received.
2012/03/23 01:07:54 [Z-Wave] Received COMMAND_CLASS_BASIC data
2012/03/23 01:07:54 [Z-Wave] Got BASIC_REPORT from node 3, value: 0
2012/03/23 01:07:54 [Z-Wave] Value changed, saving new value for node 3
2012/03/23 01:07:54 [Z-Wave] > 01 09 00 13 03 02 20 02 05 1B D8
2012/03/23 01:07:54 [Z-Wave] < 01 05 00 13 1B 00 F2
2012/03/23 01:07:54 [Z-Wave] response with callback 27 received.
2012/03/23 01:07:55 [Z-Wave] SOF found
2012/03/23 01:07:55 [Z-Wave] Packet Length = 9
2012/03/23 01:07:55 [Z-Wave] < 01 09 00 04 00 03 03 20 03 00 D1
2012/03/23 01:07:55 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:55 [Z-Wave] > 06
2012/03/23 01:07:55 [Z-Wave] Got request frame!
2012/03/23 01:07:55 [Z-Wave] Application command handler response with callback 0 received.
2012/03/23 01:07:55 [Z-Wave] Received COMMAND_CLASS_BASIC data
2012/03/23 01:07:55 [Z-Wave] Got BASIC_REPORT from node 3, value: 0
2012/03/23 01:07:55 [Z-Wave] Value changed, saving new value for node 3
2012/03/23 01:07:56 [Z-Wave] Requesting basic report for node id 4
2012/03/23 01:07:56 [Z-Wave] > 01 09 00 13 04 02 20 02 05 1C D8
2012/03/23 01:07:56 [Z-Wave] < 06 - received ACK.
2012/03/23 01:07:56 [Z-Wave] SOF found
2012/03/23 01:07:56 [Z-Wave] Packet Length = 4
2012/03/23 01:07:56 [Z-Wave] < 01 04 01 13 01 E8
2012/03/23 01:07:56 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:56 [Z-Wave] > 06
2012/03/23 01:07:56 [Z-Wave] Got response frame!
2012/03/23 01:07:56 [Z-Wave] data delivered to Z-Wave device.
2012/03/23 01:07:58 [Z-Wave] Requesting basic report for node id 5
2012/03/23 01:07:58 [Z-Wave] > 01 09 00 13 05 02 20 02 05 1D D8
2012/03/23 01:07:58 [Z-Wave] < 06 - received ACK.
2012/03/23 01:07:58 [Z-Wave] SOF found
2012/03/23 01:07:58 [Z-Wave] Packet Length = 4
2012/03/23 01:07:58 [Z-Wave] < 01 04 01 13 01 E8
2012/03/23 01:07:58 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:07:58 [Z-Wave] > 06
2012/03/23 01:07:58 [Z-Wave] Got response frame!
2012/03/23 01:07:58 [Z-Wave] data delivered to Z-Wave device.
2012/03/23 01:08:00 [Z-Wave] Requesting basic report for node id 6
2012/03/23 01:08:00 [Z-Wave] > 01 09 00 13 06 02 20 02 05 1E D8
2012/03/23 01:08:00 [Z-Wave] < 06 - received ACK.
2012/03/23 01:08:00 [Z-Wave] SOF found
2012/03/23 01:08:00 [Z-Wave] Packet Length = 4
2012/03/23 01:08:00 [Z-Wave] < 01 04 01 13 01 E8
2012/03/23 01:08:00 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:08:00 [Z-Wave] > 06
2012/03/23 01:08:00 [Z-Wave] Got response frame!
2012/03/23 01:08:00 [Z-Wave] data delivered to Z-Wave device.
2012/03/23 01:08:17 [Z-Wave] Set value for node 4 and instance 1 to 255
2012/03/23 01:08:17 [Z-Wave] Requesting basic report for node id 4
2012/03/23 01:08:17 [Z-Wave] > 01 09 00 13 04 02 20 02 05 1F DB
2012/03/23 01:08:17 [Z-Wave] SOF found
2012/03/23 01:08:17 [Z-Wave] Packet Length = 5
2012/03/23 01:08:17 [Z-Wave] < 01 05 00 13 1E 01 F6
2012/03/23 01:08:17 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:08:17 [Z-Wave] > 06
2012/03/23 01:08:17 [Z-Wave] Got request frame!
2012/03/23 01:08:17 [Z-Wave] response with callback 30 received.
2012/03/23 01:08:17 [Z-Wave] CAN received.
2012/03/23 01:08:17 [Z-Wave] < 01 05 00 13 1E 00 F7
2012/03/23 01:08:17 [Z-Wave] Packet Length = 9
2012/03/23 01:08:17 [Z-Wave] < 01 09 00 04 00 06 03 20 03 00 D4
2012/03/23 01:08:17 [Z-Wave] Application command handler response with callback 0 received.
2012/03/23 01:08:17 [Z-Wave] Received COMMAND_CLASS_BASIC data
2012/03/23 01:08:17 [Z-Wave] Got BASIC_REPORT from node 6, value: 0
2012/03/23 01:08:17 [Z-Wave] Value changed, saving new value for node 6
2012/03/23 01:08:57 [Z-Wave] Requesting basic report for node id 4
2012/03/23 01:08:57 [Z-Wave] > 01 09 00 13 04 02 20 02 05 20 E4
2012/03/23 01:08:57 [Z-Wave] SOF found
2012/03/23 01:08:57 [Z-Wave] Packet Length = 14
2012/03/23 01:08:57 [Z-Wave] < 01 0E 00 04 00 06 08 32 02 21 12 00 00 00 00 F8
2012/03/23 01:08:57 [Z-Wave] Checksum correct - sending an ACK.
2012/03/23 01:08:57 [Z-Wave] > 06
2012/03/23 01:08:57 [Z-Wave] Got request frame!
2012/03/23 01:08:57 [Z-Wave] Application command handler response with callback 0 received.
2012/03/23 01:08:57 [Z-Wave] Got unsupported FUNC_ID_APPLICATION_COMMAND_HANDLER type: 32, ignoring
Posted: Sat May 19, 2012 6:58 pm
by uAlex73
It is working with the Open Z-Wave now? If it doesn't work, please update to r527 of the Open Z-Wave (and Domotiga 0.1.206) and enable debugging and look in the ~/domotiga/wrapper/domozwave/OZW_Log.txt file. Check if your serial port is properly initialized. This can take a moment if you are running under VM (i patched my serial driver to have a longer time-out)
