Connection RFXio
Posted: Mon Apr 30, 2012 2:18 pm
by phoenixb
Maybe a simple question but i want to be sure.
Is it possible to connect on a output of the RFXio a 230Vac line? because i want to control a 230Vac device but i see 1 pcb path direct to the (i think) opto coupler.
Re: Connection RFXio
Posted: Mon Apr 30, 2012 6:08 pm
by b_weijenberg
The Opto-coupler has an isolation Voltage of 5kV so it should not be a problem.
Do not install the resistor (R2,R5...R23) to the opto-coupler!
I think the relay can switch 230V AC but I'm not sure so check the relay.
