Rfxcom Lan transceiver moving to Homeseer
Posted: Tue May 29, 2012 9:47 pm
by mrqnapper
I have been using the RFXcom Transceiver in Domotiga, which worked out very well. Now I'm testing HomeseerPro to find out if it brings more for using Z-wave, and have some questions about the use of the RFXCom Lan transceiver.
1. can I use the Lan transceiver for Homeseer and Domotiga with the same software on it?
2 Can I take the settings as I have them for the devices in Domotiga als for use in Homeseer? I have a few devices, amongst others a HE remote, a few sensors, and a build in KAKU switch which I want to use in Homeseer as well. Now it would be easy if I just can take the values from the Domotiga device settings (I now receive the code from the sensor, and the remote button addresses)
Any advice on this? Thanks.
Re: Rfxcom Lan transceiver moving to Homeseer
Posted: Wed May 30, 2012 10:48 am
by b_weijenberg
the RFXLAN can only be connected by one application.
It is easy to add devices in the RFXCOM plug-in. Check the Homeseer Quick Start Guide (in the HS docs\RFXCOM directory)
Posted: Wed May 30, 2012 11:07 am
by mrqnapper
Ok, will have a look at that info. Do I have to change the software settings on the RFXcom Transceiver for use with Homeseer? I already tried to connect it in Homeseer but did not succeed yet.
Posted: Wed May 30, 2012 11:14 am
by b_weijenberg
you have to disconnect DomotiGa from the RFXLAN before you can use it in Homeseer.
Configure a receiver on port 10001 and transmitter (with RFXmitter and handshake checked) on port 10002
The settings in the RFXLAN are the same.
Posted: Wed May 30, 2012 1:25 pm
by mrqnapper
Ok thanks. I have it connected now and see already some package received info (from the sensor) popping up.
Posted: Fri Jun 01, 2012 3:52 pm
by mrqnapper
I managed to get one device working. Now I have devices build in behind a wall switch. So I tried to get the unit codes for these devices to add them manually. Now when looking in the RFreceiver I Catch the input I have from the remote (which also switches the devices) I get 0039A92 unit 3. If I receive the remote in the RFXPlug in Homeseer it will add the remote device as: AC[0E6A480]a
Now when I add a new device it gets A3 as id and after pushing the learn button on a device the address shows 1 80 00 00
Now having the 0039A92 unit 3 address I tried to input as an address code : 0 39 A9 23 Which is not working? So what address should I use there?
Can you give me some direction how to do this without opening my wall switches again
Thanks.
Wiechert
Posted: Sat Jun 02, 2012 10:35 am
by mrqnapper
I have had a look at the Homeseer/RFxCompluging/usermanual etc. But that did not help me getting this done. Any advice on how to add an address code for a device manually as I mentioned in my previous post? Thanks.
Posted: Sun Jun 03, 2012 11:49 am
by b_weijenberg
you should add a Homeseer device with device code 3 and ID 0 03 9A 92
Posted: Sun Jun 03, 2012 10:07 pm
by mrqnapper
Thanks I just tried it and this works very well. Nice.
Now I have my HE303 Pir as input for an event which switch on and off (with a 20 minute wait) my (HE)AC Module.
