problem with com verbinding powermax pro
Posted: Sun Jun 10, 2012 8:27 pm
by Akatar
i own a powermax pro with a tag reader,
there is a gsm350 module and a powerlink2 module build in, now i ad a dual rs232 modul for the homeseer plugin, and here is the problem:
i can not connect with the powermax pro, i own the version with 1 installer code (9999). there a versions with two codes: 9999 and 8888
tried so far:
serial to usb convertor
serial to ethernet convertor
laptop with a normal rs232 port,
all no joy, no communication.
ideas are welcome
Re: problem with com verbinding powermax pro
Posted: Mon Jun 11, 2012 12:03 am
by Noel
The only way that I can connect to my Powermax Pro is if I use COM 1, 2 or 3.
Anything above does not work for me!
I'm using a serial to usb convertor.
Give a low COM port a try.
Maybe you have the same problem?
Posted: Mon Jun 11, 2012 12:17 am
by Akatar
i tried com1 on a "real" comport,
that did not work either.
Posted: Mon Jun 11, 2012 12:19 am
by Phaeton
Try taking the powerlink off. The plugin emulates one, so mu guess is the real and emulates plugins are conflicting.
Posted: Mon Jun 11, 2012 6:59 pm
by Akatar
it didn't work with the original software either.
and my pro version has seperate com ports, old ones uses a rs232 port for cell phone and powerlink
(as far as i know)
Posted: Mon Jun 11, 2012 7:26 pm
by Rene
Only the Powermax Plus has one COM port, the RS232 module for Powermax Pro's has two COM ports, the one on the left is to connect the Powerlink or a PC, the one on the right is to connect a PC. Be careful with the one on the left, this one feeds 12V to the Powerlink. When using a wrong connector (e.g. a RJ45->DB9 with all pins connected) will burn your RS232 interface. Only use the RJ45->RS232 connector that came with the RS232 module, this one has connected 3 pins only.
Have you already tried disconnecting the Powerlink2, as Phaeton suggested?
Posted: Mon Jun 11, 2012 8:38 pm
by Akatar
i disconnect the powerlink2, and yes, now it works.
a bit strange that powerlink and rs232 can't work together.
thanks for all the help/advise!
Posted: Mon Jun 11, 2012 9:17 pm
by Rene
You won't need it any longer ;-)
Posted: Mon Jun 11, 2012 9:33 pm
by Akatar
yes, i do need the powerlink2. see problems with beta plugin :)
Posted: Mon Jun 11, 2012 10:06 pm
by Rene
This will be fixed in the final release ;-)
