ZME Dual Sensor
ZME Dual Sensor
Tested the new Dual sensor from Zwave Europe
See my short review in Dutch
http://blog.tane.nl/?p=335
Google translation
http://translate.google.nl/translate?hl ... %3Fp%3D335
Google translation
Re: ZME Dual Sensor
For the conclusion we have to wait few days..
I need to change the option 2 to make usable with Homeseer..
http://board.homeseer.com/showthread.php?t=154910
Device is working fine....
7-7-2012 22:22:11 Device Update Device: Z-Wave Z-Wave Interface Child 85 Alarm Status set to ON
7-7-2012 22:22:07 Device Update Device: Z-Wave Z-Wave Interface Child 85 Alarm Status set to OFF
I need to find the device for event triggering...
Also very shot connections will be detected.
Re: ZME Dual Sensor
Hi Enver.
Can you read the temp sensor in Homeseer?
I can't find a way to do that.
If you set parameter 2 = 1, it's the sensor binary device, if parameter 2 = 0 it's the alarm device that change with the terminals.
I have tried it here http://www.zwaves.dk/forum/viewtopic.php?f=21&t=1348 (but as usual in Danish.)
Regards
Morten
Regards
Morten
Re: ZME Dual Sensor
Thanks for the update.
Temperature is working fine in Homeseer
Also found the Alarm device after rescanning.
This device is not registered to Homeseer Device list.
you can't select it form event for value change.
Status Change is available...but this is also not correct updated.
I will try the option 2 with the value 1
Re: ZME Dual Sensor
Thank you.
Now I'm happy..
Terminal output is working
I can trigger events
Now I'm happy..
- ZD.png (53.65 KiB) Viewed 12130 times
Re: ZME Dual Sensor
But how did you get the temp sensor to work? I have last change 22-06-2012 21:31:48 on mine.
Re: ZME Dual Sensor
Just the standard inclusion.
I saw somewhere that the temperature was set to zero...in the logging after few times pushing the alarm.
Did you try the option 6 with 0?
I have send the developer a short mail and asked about the wakeup time. I hope they will change this to changeable value.
15 minutes will be fine for me.
Re: ZME Dual Sensor
Update:
Do you have also this warning in your log?
Z-Wave Multilevel Sensor device ZWE Z-Wave Interface Child 85 Temperature is missing Sensor Type information - cannot update sensor status.
I have this since the change of option 2 in 1
Temperature is not updated....
Re: ZME Dual Sensor
I don't have that warning in the logs. But I have never had any luck getting a reading without refresh.
I have tried parameter 5 = 3 always on. Parameter 6 is default 0. I have not tried changing that, as I don't know, if the readings are correct.
Re: ZME Dual Sensor
I think the problem is that with option 2 settings 1 the other values are no longer correct.
Re: ZME Dual Sensor
Mine is not working right now.
I have tried setting parameter 2 = 0. That didn't change anything.
Re: ZME Dual Sensor
I have checked all the settings
Device is now connected to the Vera
Option 1 is showing 170..
Device will trigger when Option two is set to 1 (same as Homeseer)
- Screen Shot 2012-07-08 at 1.27.21 PM.png (21.98 KiB) Viewed 12104 times
Re: ZME Dual Sensor
Parameter 1 not 0 should be facroty reset?
Re: ZME Dual Sensor
I can't make mine work.
Tried rescan, reinclude, parameter 5 = 3 "Always awake". I am out of ideas.
