Domation Mono Led and Homeseer
Moderator: Mversluis
Postby TANE » Sun Aug 05, 2012 3:56 pm
[youtube]http://www.youtube.com/watch?v=-8tKSmMiDDk&feature=plcp[/youtube]
HSTouch Video
[youtube]http://www.youtube.com/watch?v=f-tL6uNMpFU&feature=plcp[/youtube]
Re: Domation Mono Led and Homeseer
Postby Snelvuur » Mon Aug 06, 2012 5:10 pm
Not bad.. always nice to place it in the kitchen :)
Snelvuur
Postby Rebel » Wed Aug 08, 2012 4:07 pm
Nice modules, I have 2 RGB in the kitchen, 3 RGB and 2 mono modules in the living.
It works perfect with the provided scripts. Both with Homseer and HS Touch!
Grtz,
Arjo
Rebel
Postby labium » Thu Sep 06, 2012 12:29 pm
what kind of plugin is being used for these leds, the link provided doesnt tell anything about the integration in homeseer. Monoled stays quite misty that way.
labium
Postby Moskus » Wed Sep 12, 2012 1:33 pm
I'd also love some more information around this, and it's integration in HomeSeer. :)
HSPro 2.5.0.60, X10 CM11, Z-wave Aeon Stick2, RFXCOM, Script Connector, BT connector, DI Connector, DooNetwork, HSTouch, Squeezebox plugin, iTach WF2IR & GC-100-6 with UltraGCIR, BLicon, DenonAVR, WebcamXP, Jon00s MaxiBee and Webpage builder
Moskus
Postby mrtiger » Sat Sep 15, 2012 5:33 pm
Not much info about the hardware.....
mrtiger
Postby TANE » Mon Oct 01, 2012 7:56 pm
Sorry for the late response.
Some info:
Domation products are works on 868mhz
In Domation network you can add 255 devices
Every device can be controlled individuel or all at once.
Every Led drive can control up to 3 mono strips or one RGB strip (7A)
Current PC interface is USB (FTDI) RS232 on request
The PC interface will also be usable in the future for other Domation products. (Remote RS232, Remote I/O. ARFID, RFID)
Current Homeseer integration is based on HS scripting.
Homeseer Create script will build the HS devices that can control the led strips.
More info about the Homeseer scripts
http://tane.nl/shop/domation/homeseer/
Vera scripts are in the make.
HomeSeer mono devices.png (41.27 KiB) Viewed 10159 times
HomeSeer RGB.png (25.7 KiB) Viewed 10159 times
Postby Moskus » Mon Oct 01, 2012 8:25 pm
Very, very interessting. Do you ship to Norway?
Moskus
Postby TANE » Mon Oct 01, 2012 8:42 pm
please contact me by mail..
as MR. Homeseer I hope you van optimise the script a bit more or a plugin...:)
Postby Moskus » Mon Oct 01, 2012 8:47 pm
TANE wrote:please contact me by mail..
I was thinkink about a plugin, actually. ;)
But first to have another look at the scripts, it would be cool to have a slider for each of the RGB values.
I'll just have to decide if I can justify the cost... I'll send you an email.
Moskus
Postby TANE » Mon Oct 01, 2012 8:49 pm
Plugin will be great..
as you cab see in the scripts commands are very basic.
I will contact you by mail..
Postby mrtiger » Mon Oct 22, 2012 9:08 pm
Is there enough light in them too use them outside?
mrtiger
Postby Moskus » Tue Oct 23, 2012 8:01 am
mrtiger wrote:Is there enough light in them too use them outside?
That really depends on what light you connect and how much light you require, as long as you only use 12V leds.
Moskus
Postby mrtiger » Wed Oct 24, 2012 10:22 pm
Where and how can i buy it?
mrtiger
Postby Moskus » Thu Oct 25, 2012 8:42 am
Moskus
Next
Return to LEDS, DMX & Lights Forum
