Homeseer RFXCOM plug-in
- b_weijenberg
De RFXCOM plugin voor Homeseer is beschikbaar op http://www.rfxcom.com/downloads.htm
Vereisten:
- Homeseer versie 2.2.0.66 of hoger.
- De 310MHz ontvanger moet versie 32 of hoger hebben,
- De 433.92MHz X10 ontvanger moet versie 21 of hoger hebben,
- De ontvanger voor Visonic sensors moet versie 8C of hoger hebben.
- Alle transmitter versies kunnen gebruikt worden.
Vereisten:
Bert,
Gefeliciteerd met je fantastische Homeseer plugin.
This is a great plugin for Homeseer and the Homeseer users
I examined the plugin and it's a real must have for those who use the RFXCOM products and Homeseer. (English by eception)
<h3>Description</h3>The RFXCOM plug-in enables the connection of the RFXCOM transmitter and/or RFXCOM receivers into Homeseer.
By means of the RFXCOM plug-in, the RFXCOM transmitter can control:
KlikOn-KlikOff, ELRO AB600, NEXA, Flamingo and Domia Lite modules,
X10 lighting modules and the X10 security panel,
Harrison electrical curtains.
The RFXCOM plug-in is able to receive sensor and remote data from:
X10 lighting and security sensors and remotes,
Oregon Scientific sensors,
KlikOn-KlikOff remotes, wall-switches and chimes,
Visonic/SecureLinq PowerCode sensors and CodeSecure remotes,
ATI Remote Wonder,
RFXSensor,
RFXMeter with RFXPulse and RFXPwr modules.
<h3>Requirements</h3>Homeseer 2 with at least version 2.2.0.66,
All versions of Microsoft .NET Framework installed, (1.1, 2.0, 3.0 and 3.5)
An USB or Ethernet connected RFXCOM receiver,
Or an USB or Ethernet connected RFXCOM transmitter.
Here some screenshots:
Pieter Knuvers
ATI Remote Wonder,
RFXSensor,
Pieter Knuvers
- Snelvuur
Ziet er mooi uit bert, denk dat er weer wat fans bij het clubje komen.
en natuurlijk ook wat leuke charts
He Chak
The Weighwatcher is working for you
For now!
For now!
That's not my weight..
I think it's the scale of my neighbors..[:D]
Then it could be my weight, are the sensors that good
I've tried a few packages, but I think I will go with homeseer from now on.
As I can see the text on the rfxcom site:
Plug-in requirements:
- The plug-in needs Homeseer version 2.2.0.66 or higher.
- The 310MHz receiver must have version 32 or up,
- the 433.92MHz X10receiver must have version 21 or up,
- the receivers for Visonic sensors must have version 8C or up.
I don't think this is going to work, due to the lower visonic version?
Version request to receiver => F020
4D1D538B Version Master=1D Slave=8B
Master =X10 receiver, slave is visonic
Is there an easy way to upgrade the firmware, Or is it tricky to break it?
Within homeseer loggin it also says:
Type: RFXCOM
(RexRxChar) Warning: receiver didn't respond with 2C, retry
(RexRxChar) Error: reveiver #2 didn't respond corretly to the init cmd.
(RexRxChar) Error: receiver on Com0 not used!
(but I don't use com0 on the pc, just com3 for the reveiver, and com4 as transmitter)
At the moment, I don't get anything in the logging from the master or the slave rfxcom.
Type: RFXCOM
- b_weijenberg
Your receiver versions are not supported by the plug-in and you need to upgrade them.
http://www.rfxcom.com/receivers.htm#update
Or use the ACRF2 plug-in.
Bert
Bert
Bert gefeliciteerd!
Prachtige plugin voor Homeseer. Ik heb hem nu ruim een maand kunnen proberen en ik kan niets anders zeggen dat dit de missende link is die Homeseer in Europa had.
Ook je ondersteuning en input is indrukwekkend snel en duidelijk!
Vooral het gebruiksvriendelijk maken van de transmitter functies zorgt ervoor dat de RFXCOM versie handiger is dan de ACRF2 plugin.
Zoals zo velen ben ik aan het rommelen met de verschillende charting software. Om de WAF hoog te houden kan ik er op dit moment alleen niet genoeg tijd in steken.
Willem-bram
HS 2.0 / JvCADDX / SKYPE connector / RFXCOM / Moony / Mainlobby
Willem-bram
<blockquote id="quote"><font size="1" face="Verdana, Arial, Helvetica" id="quote">quote:<hr height="1" noshade id="quote"><i>Originally posted by glabbeek</i>
<br />Bert gefeliciteerd!
Willem-bram
Willem-bram
- b_weijenberg
De RFXCOM plug-in ondersteunt ook de Harrison electrische gordijnrail.
In de bijlage wordt uitgelegd hoe aan de gordijnrail een adres kan worden toegekend.
<b>Download Attachment:</b> [img]images/icon_paperclip.gif[/img] Instellen Harrison.pdf<br />27.18 KB
- b_weijenberg
Versie 6.0.0.5 van de RFXCOM plug-in is beschikbaar in de Homeseer Updater.
Input Sensor High-Low warning-alarm toegevoegd,
Configuratiepagina's voor input sensors uitgebried,
ontvangst van AC remotes & sensors (HomeEasy/KlikAan-KlikUit) toegevoegd,
path voor humidity icons gewijzigd,
hspi.RFXCOM function GetLastMessage gewijzigd in GetLastAlarmMessage,
hspi.RFXCOM function GetLastSensorMessage toegevoegd,
Alarm Panel display DeviceValue wordt opgehoogd bij een nieuw bericht. Hier kan dus een trigger op gezet worden,
Water chart gecorrigeerd,
SMS scripts toegevoegd,
Sensor Message Panel toegevoegd.
Belangrijk: maak Input Device 1 vrij voordat je het Sensor Message Panel activeert op de Input Device configuratie pagina. Het Sensor Message panel maakt vast gebruik van Input device 1. Wijs een nieuw adres toe aan sensor 1 en wijzig het sensor nummer ook in de database als de sensor een chart functie heeft.
Hallo Bert,
Er zitten nog een paar kleine foutjes in de water chart
er staat overal m3 in plaats van liters.
Marcel
www.myhomecontrol.nl
Marcel
