RFXtrx433 vs Lacie Network Space 2
Posted: Tue Aug 07, 2012 7:35 pm
by math1985
I am trying to see if it is possible to connect my Lacie Network Space 2 (Lite) NAS to the RFXtrx433 from RFXCOM.
The kernel of my NS2 is a custom kernel, 2.6.31.14-svn6790.
The RFXtrx433 uses the virtual com port driver from FTDI, which is available as a kernel driver.
- Would it be possible to add a kernel module? 'make'ing the kernel module fails with 'ftdi_sio.c:253:24: error: linux/init.h: No such file or directory', as I do not have the header files. However, Lacie seems to provide kernel sources. Can I derive the header files from these?
- Would there be a way to access the RFXtrx433 with libFTDI instead of with the FTDI kernel module?
- Is the NS Lite 2 already supported in the vanilla kernel?
Thank you in advance for any answers.
Re: RFXtrx433 vs Lacie Network Space 2
Posted: Thu Aug 16, 2012 10:10 pm
by math1985
I found out that installing kernel modules is indeed possible. I documented this process at http://lacie.nas-central.org/wiki/Insta ... Space_2%29 .
