I have an MS90 which I'm testing before putting outside, it's currently sending status 0x84/0x85 indicating "tamper".
Is there a way to reset the tamper flag?
thanks,
Kevin
MS90 and RFXtrx433
- b_weijenberg
Re: MS90 and RFXtrx433
the sensor enclosure and battery compartment are closed?
Yes, the sensor enclosure and battery compartment are closed.
I have no SC9000, so it's possible that it can't be done, I do notice that heyu has a "clrtamper" command, will see what that does.
thanks,
Kevin
thanks,
Kevin
So, I got it working, but I'm not sure what happened, I did reseat the batteries, and close the case, but I was experimenting with various messages, is it possible from software?
