RFXtrx433 Firmware
raymonvdm
RFXtrx433 Firmware
Post by raymonvdm »
Last week i update my RFXtrx433 Firmware from version 55 to version 60 and i noticed that my KAKU modules and HE modules became unstable. Did other users also experience this.
I have rejoined my HE modules (Push button on unit until blinking and switch the unit on 3 times using HomeSeer)
I have unplugged an Kaku module to get this to switch again.
I did not had this issue using version 55 (and wil try to downgrade back to this version)
b_weijenberg
Re: RFXtrx433 Firmware
Post by b_weijenberg »
Can you explain what you mean by "became unstable"?
Which Home Automation software is used?
There are no changes for AC and HE transmit commands compared to version 55. (it was at least not the intention)
this is the list of firmware changes:
FW release 433_60 27-11-2012
RisingSun ON command corrected
Hideki wind speed corrected
FW release 433_59 25-11-2012
Hideki wind speed, wind direction and rain total corrected
FW release 433_58 19-11-2012
Rubicson temp below 25 degrees corrected
LWRF mood4 & mood5 added
FW release 433_57 14-11-2012
CM119/CM160, CM180 battery sensor corrected
FW release 433_56 9-11-2012
ATI and LightwaveRF no longer enabled by default
WIND3 battery level corrected
Meiantech/Atlantic PB500R,PB201R, MD2018R, siren tamper added
Temperature of the TFA UV sensor corrected
RTS10/Digimax transmit updated
Aidebao IR beam added
CM113 count added
CM180i ELEC4 added
LaCrosse optimized
Blyss optimized for HW version 0.0
Disable receive protocol cmds removed
Enable all RF cmd removed
Enable undec cmd removed
raymonvdm
Post by raymonvdm »
I`m using HomeSeer with the RFXcom plugin.
With become unstable i mean that the unit will switch on but never of. After rejoining (using the button on the device and switching on 3 times) the on/off is working again. I had this issue with one HE module which is on top of my drawer (not the most handy place) I also had an issue with an Kaku module on house code Mxx which needed a power cycle. Bufore the upgrade al went well for weeks. No i had this issues in one week.
I think it has something to do with version 60
b_weijenberg
please try with the previous firmware version.
