I restarted this project last week, but without much success so far. At first i tried to use ESPEASY as a pulse counter but the ESP Easy seems to be missing a lot of pulses. Since i`m no arduino guru i`m still strugeling to get soms sort of ino file working
I will try this one later on
https://github.com/incmve/Sensus-waterm ... rmeter.ino
And already tried these one
http://www.instructables.com/id/Flowmet ... ng-Litres/
https://ubidots.com/blog/build-a-people ... d-ubidots/
I`m using a NodeMCU and
this sensor. The sensor connects the GPIO to ground when counting a pulse. I have ordered 3 of them (NPN Type). But one sensor is the PNP type which gives me 12 volt when counting a pulse. The pulse couting seems to be running fine, en the output seems to be a nice block (no ripple)
The PNP is also tested with this
schema
I would like to have a sensor which will send the data using MQTT and HTTP Post for Domoticz
