Automating my BBQ
Posted: Thu Jan 17, 2013 10:28 pm
The most fun projects are when two hobbies come together. I have been bbq-ing since quite a while but the last couple of years it has become more of a hobby. For more serious bbq-ing you start to prepare your meat at lower temperatures and thus the preperation times will automatically grow longer. To give an idea when you prepare pulled pork, sessions of more then twelve hours are fairly normal. During those preperations the temperature needs to be controlled fairly precisely. With most bbq's you control the temperature by opening and closing mechanical valves.
This can ofcourse not easily be automated but ofcourse there have been some clever guys that have figured out a manner howto do this. But those systems are fairly expensive, so I have decided to build up my own system using a couple of jeenodes.
The first jeenode the bbq-controller will have the task to measure and control the heat. The second jeenode (masternode) will acts as a gateway and will have a network card and acts as a gateway to pass along messages between the bbqcontroller and the server which will actually create graphs. The first idea was to 'host' the network part in my domotica software, but due to some interest from a bbq-forum I hang out I have decided to build a standalone webapplication for this.
Now some more details about the bbq-controller. The bbqcontroller will measure up to four probes using the analog ports on the jeenode. The probes are basically NTC's so a simple voltage divider is sufficient. One of the probes is the probe which will be placed on the grill and that temperature will be regulated to a configurable setpoint. But how to control the temperature for a bbq? Well this is fairly easy, first up you close up the regular airvents and the over one the vents you place a fan. The fan is also controlled by the jeenode using a mosfet. The jeenode will use PWM to control the fan faster or slower. The setpoint is then controlled using a technique called PID-tuning. This sounds very fancy, but once I started surfing around howto do this in detail, I found out that somebody already did this and place the complete source code on github so the bbqcontroller was created fairly quickly.
The only thing I added was the two way communication between controller and the server and I have refactored the sourcecode a bit so it suits my style a bit better.
Since pictures say more then a thousand words.
The masternode on the left, the bbqcontroller on the right:
A close up shot of the measurement board of the controller:
A calibration run cooling boiling water down, to get the steinhart coefficients for the probes:
The fan mounted in it's housing and connected to the airvent of the bbq using water 'piping'.
The first test run showing the complete setup, the fan can be shown below, two temperature probes are fed-in above. One is connected to a commercial temperure logger the second fed-in to my bbq-controller.
Every bbq-session is now started with the definition what you will prepare and what the setpoint of the grill will be:
During a session the temperature is completely controlled by the bbq-controller. This will periodically send the temperatures and fanspeed to the masternode, which will push the values to a webserver. The values will be then forwarded realtime to the webbrowser using signalr (using websockets or long polling depending of your browser). Realtime monitoring of the temperature is done using the gauges on the left and every now and the values are stored in db and a refresh of the XY-graph is forced (also using signalr). The graphing is done using Google Charting. In images instead of text:
In the picture above I was preparing a so-called fatty, but since we got hungry (at 1 hour and 45 mins), I decided to jack up the temperature. Very funny when you can do that from inside your house using your ipad
And now to show what kind of stuff takes these long preperation times, the following is called a 'procureur' weighing roughly 2-3 kilo's.
And looks like this when prepared:
And like this when you're about to eat it:
To conclude I am very happy with this project, but for sure will miss the days camping around the entire night with a beer in my hand
Thanx for watching.
Thanx for watching.
