Simulating Max! Thermostat
Posted: Mon Feb 11, 2013 7:27 pm
by peep
Hey,
I read in your forum and like your work on the Max! protocol very much. i work in a r&d department and know how difficult it could be to understand a foreign protocol.
I want to use the Max! Wall Thermostat and the cube, but i can't use the radiator thermostat, cause we have electric heater.
To work properly the Max! System needs such a thermostat. So here is my question.
Can someone tell me:
- what information the radiator thermostat sends to the cube (in normal operating mode and when it is pairing with the cube)?
- How it is send?
Unfortunately I have no experience in RF Applications, so there i would need a bit more help ;P
I would rather pay more if it's easier... (e.g. buy a complete rf-module)
Thanks and greetings from germany
Timo
Re: Simulating Max! Thermostat
Posted: Tue May 21, 2013 2:26 pm
by Kingsammy
Hallo Timo,
for electrical heaters or boilers you can use the "MAX! Zwischenstecker" (ON/OFF-Switching) which you can obtain here: http://www.ewe.de/privatkunden/ewe-spar ... eizung.php
And in addition with a MAX! Wallthermostate you can use the "MAX! Zwischenstecker" as a temperature regulated ON/OFF-switch.
Note: From ELV the Zwischenstecker could not be obtained yet.
Greetings
Kingsammy
