Opentherm (cannot open /dev/ttyUSB0)
Posted: Mon Feb 18, 2013 3:23 pm
by PHiAX
So, i've been trying to get started with domotiga, but i can't figure it out.
Started with an old laptop with a defective screen, installed ubuntu 12.04 server, gambas 2 and domotiga on it. Tried to add the opentherm gw i build to show thermostat setpoint and such, could not find any information on how to do this so just filled in a name and location. But nothing would show up. Tried the opentherm monitor program from the same site and the schematic and got results.
Then the wireless adapter of the laptop failed. So i put everything on hold and ordered a raspberry pi.
Installed wheezy image, gambas 2 and domotiga on that, then the gw died. Transistor damage. Got my brother to check everything, then hooked up the GW again. checked if it was working with otmonitor again. it was. Changed thermostat setpoit, that worked. Added the opentherm interface with auto device creation setting and then... nothing...
Log shows something along the lines of: Device not found, Cannot open /dev/ttyUSB0.
I can do "cat /dev/ttyUSB0" and see opentherm codes flying all over the place.
The otmonitor can also read and write to the ttyUSB0 without problem.
Can someone please help me to get this to work? :cry:
Re: Opentherm (cannot open /dev/ttyUSB0)
Posted: Mon Feb 18, 2013 10:20 pm
by BreFra
To me it looks like you domotiga does not have the proper permission to open the port.
otmonitor and domotiga both running using the same credentials?
Posted: Mon Feb 18, 2013 11:24 pm
by PHiAX
Yes, both run under root. decided to ignore the huge security warning for now.
Posted: Tue Feb 19, 2013 8:37 pm
by vanisher
sometimes you have to change the ownership of /dev/ttyUSBx
Posted: Wed Feb 20, 2013 1:08 am
by PHiAX
The port is already owned by the root user, the owner group is dailout, root is already a member of this group. I've also run chmod 777 /dev/ttyUSB0.
Anything else i might be able to try?
Posted: Wed Feb 20, 2013 1:16 am
by PHiAX
Also here's some output:
2013/02/20 00:14:01 OpenTherm gateway support enabled.
2013/02/20 00:14:01 [Devices] Interface with name 'OpenTherm Gateway' has id '37'
2013/02/20 00:14:01 [Devices] Device with address 'Thermostat' is 'OpenTherm Thermostat device #1'
2013/02/20 00:14:01 [Devices] Device with address 'CentralHeating' is 'OpenTherm Central Heating device'
2013/02/20 00:14:01 [Devices] Device with address 'Boiler' is 'OpenTherm Boiler device #1'
2013/02/20 00:14:01 [Devices] Device with address 'Burner' is 'OpenTherm Burner device #1'
2013/02/20 00:14:01 [Devices] Device with address 'Outside' is 'OpenTherm Outside sensor device '
2013/02/20 00:14:02 [OpenTherm] Gateway is not responding
2013/02/20 00:14:02 ERROR: OpenTherm gateway interface FAILED to connect to Port /dev/ttyUSB0
And ls -l gives:
crwxrwxrwx 1 root root 188, 0 Feb 20 00:16 /dev/ttyUSB0
Posted: Thu Feb 21, 2013 12:54 am
by FoRMaTC
What is lsusb giving you?
Posted: Thu Feb 21, 2013 1:05 am
by PHiAX
lsusb returns:
Bus 001 Device 002: ID 0424:9512 Standard Microsystems Corp.
Bus 001 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 001 Device 003: ID 0424:ec00 Standard Microsystems Corp.
Bus 001 Device 004: ID 148f:5370 Ralink Technology, Corp. RT5370 Wireless Adapter
Bus 001 Device 005: ID 0403:6001 Future Technology Devices International, Ltd FT232 USB-Serial (UART) IC
Posted: Thu Feb 21, 2013 10:39 pm
by BreFra
Your debug log pointed me to a bug in the DomotiGa code that prevents activating the OpenTherm interface. (Apparently I mixed up "WAIT" and "SLEEP" commands :oops: )
I've just created a bug request (http://www.domotiga.nl/issues/253) to get this fixed.
Posted: Fri Feb 22, 2013 11:21 am
by PHiAX
Wow thanks :)
I'll wait for a fix then
Posted: Wed Mar 06, 2013 11:28 pm
by sj3fk3
instead of running as root you can do something like this in /etc/udev/rules.d/70-usb-serial.rules
KERNEL=="ttyUSB*", SUBSYSTEMS=="usb", ATTRS{serial}=="serialstringoftheusbdevice", SYMLINK+="otgw", OWNER="username"
Posted: Fri Mar 08, 2013 6:26 pm
by MartinF
click on FAQ on domotiga.nl and you have fix for it there.
