Page 33 of 39
Posted: Sun Sep 03, 2017 8:35 pm
by marcelr
Not sure what you mean.
The rooting manual lists the files that require editing for getting in (you already did that). All the rest is up to you. in /HCBv2/qml/apps/ you can edit whatever you like, although some edits may be more useful than others.
Posted: Sun Sep 03, 2017 10:08 pm
by michel30
Ah okay I see
thanks for your information.
Posted: Tue Sep 05, 2017 7:10 pm
by michel30
I was playing a bit with VNC and restarting the Toon.
What I notes is as follow:
1: Restart on the Toon will not connect with VNC.
2: Restart in VNC will connect automatic back in VNC.
When I restart the Toon in the menu and login with SSH and check if VNC is running than I see it is running and can also login with VNC.
It looks like that VNC is disconnect the ports after restart but when you do a restart in VNC than the login works.
Posted: Sun Sep 10, 2017 11:20 pm
by michel30
Hello All,
The numbers are too high see screenshot
- temf.jpg (3.89 KiB) Viewed 14547 times
is there a place where you can customise this?
Can you also customise temperature for example 21,2 or 21,3 now you see always 21,5 or 22,0 or 21,0 or 20,5.
Posted: Mon Sep 11, 2017 10:59 am
by Toonz
michel30 wrote:Hello All,
This is a bug in the latest firmware (also discussed on the Eneco Toon forum).
you can customise the temperature display in the Thermostat App (I believe posted earlier on this forum)
Posted: Fri Sep 15, 2017 11:12 pm
by michel30
I installed on my Synology NAS the following app: Domoticz home automation system.
In this app is an option add Toon thermostat but you need to fill in the user name and password from Eneco so you need a subscription.
Is it possible to connect the rooted Toon without any subscription? so you can control the Toon also with this app ?
I could not find anything on the web about this.
Thanks,
Michel
Posted: Sat Sep 16, 2017 8:08 am
by Toonz
Posted: Sat Sep 16, 2017 10:51 pm
by michel30
I fixed my problem with:
- temf.jpg (3.89 KiB) Viewed 14412 times
How:
in the folder ' /HCBv2/qml/apps/thermostat', you will find the file ' ThermostatApp.qml'
In the file 'thermostatSidePanel.qml', the right side of the homescreen is drawn, including the current temperature, the buttons to increase/decrease the temperature and showing and selecting the current temp program. At line 58 I found the following code:
currentTemperature = app.thermInfo['currentDisplayTemp'] / 100.0;
Change the line in:
currentTemperature = app.thermInfo['currentTemp'] / 100.0;
The current temperature in house will also 21.1 or 21.2 etc and the number 18 will also show normal in line.
- okay.jpg (4.04 KiB) Viewed 14412 times
Posted: Mon Sep 18, 2017 3:45 pm
by walberg
How do i open port 7080 in iptables.conf?
This is my iptables.conf
*nat
:PREROUTING ACCEPT [0:0]
:POSTROUTING ACCEPT [0:0]
:OUTPUT ACCEPT [0:0]
COMMIT
*filter
:INPUT ACCEPT [0:0]
:FORWARD ACCEPT [0:0]
:HCB-INPUT - [0:0]
-A INPUT -j HCB-INPUT
-A FORWARD -j HCB-INPUT
-A HCB-INPUT -m state --state ESTABLISHED,RELATED -j ACCEPT
# These are all closed for Quby/Toon:
-A HCB-INPUT -p tcp -m tcp --dport 5900 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 22 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 80 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --dport 10080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
#-A HCB-INPUT -p udp -m udp --sport 67:68 --dport 67:68 -j ACCEPT
#-A HCB-INPUT -p udp -m udp --dport 137:138 -j ACCEPT
-A HCB-INPUT -i lo -j ACCEPT
-A HCB-INPUT -i tap+ -j ACCEPT
-A HCB-INPUT -i tun+ -j ACCEPT
-A HCB-INPUT -p tcp -m tcp --tcp-flags SYN,RST,ACK SYN -j DROP
-A HCB-INPUT -p udp -m udp -j DROP
COMMIT
Posted: Mon Sep 18, 2017 4:18 pm
by marcelr
Copy this line:
to make it look like this
-A HCB-INPUT -p tcp -m tcp --dport 7080 --tcp-flags SYN,RST,ACK SYN -j ACCEPT
then execute
/etc/init.d/iptables restart
Posted: Mon Sep 18, 2017 5:15 pm
by walberg
Thanks.
And /etc/init.d/iptables restart is a lot quicker than reboot.
Posted: Sat Oct 14, 2017 7:38 am
by Nelus82
Thank you for the great manuals! I rooted my second hand Toon without any big problems.
Only a small problemen, after editing InternetSettingsAp.qml I stille get the warning in the gui. I cant supress it.
* already found it on the forum!
How do i add zwave to the toon, cant find it in the menu. Do i have to install the package manually?
Posted: Wed Oct 18, 2017 8:46 am
by ronalddehaan
al_n wrote:Just a little toon UI hack to hide the annoying error notification when you are not connected to eneco.
In the file /HCBv2/qml/apps/internetSettings/InternetSettingsApp.qml after line 369:
smStatus = parseInt(statemachine);
add the following
if(smStatus == _ST_INTERNET) {
smStatus = _ST_TUNNEL;
Somehow the code in my InternetSettingsApp.qml file is different, can someone help me with the proper code for my file?
Posted: Wed Oct 18, 2017 7:27 pm
by michel30
You don't need to do that, see Notifications bar toppic what you want to do is old.
Posted: Tue Oct 24, 2017 7:38 am
by ronalddehaan
michel30 wrote:You don't need to do that, see Notifications bar toppic what you want to do is old.
ah thanks, didn't know it was already outdated. I'll have a look.
