Goodmorning,
I'm a starter concerning Plugwise adapters and I'm reading a lot about these plugs on this forum.
Now I have the following problem:
From long ago I've a Home Basic set lying around and I finally wanted to install these plugs.
They have (Stick, Circle+ and Circles) a Fw from 2007!
Source 2.23 can't read out these plugs, but can connect to them,
I've tried to install Source 2.17 to upgrade the FW, but 2.17 can't connect to the Circle+.
Even after polling for 2 days (at the screen 'Connectting to Circle+) in the config wizard.
Question: Is there anybody who has an older Source version than 2.17?
Hopefully I can use that version to upgrade the FW one version higher and then I can upgrade the rest with 2.17 and 2.23.
Or maybe an alternative fw or way to force a FW update?
Thanks in advance.
Droop
Newbie: Old Plugwise fw and Source
Re: Newbie: Old Plugwise fw and Source
Goodmorning,
Nobody has an old Source version archived that I can try?
Like version 2.15 or older?
Thanks in advance,
Droop
Thanks in advance,
Droop
Did u also reset the stick?
Probably the best is to reset everything, it is hard to do but possibly the only option if the stick doesn't connect to the c+
Yes, I've resetted everything multiple times.
Resetting the whole system isn't troublesome..
I downloaded some older versions (2.12, 2.14, 2.22) and 2.22 seems to find everything but couldn't upgrade the firmware.
So I think I need another (temporary) Stick and Circle+ with a recent fw to hook the other Circles to, or is there any other custom firmware out there to try?
Otherwise I'm going to switch to another system (like Youless) and dump these plugs
Did u try 2.17? I updated the older firmware with Source 2.17
