KAKU ACDB6500
Posted: Mon Jun 24, 2013 11:06 am
I have connected the transmitter of the ACDB6500 doorbell to my existing doorbell (using a relay switch). Now, when I press the doorbell, my existing doorbell sounds, it activates the relay, the Kaku transmitter sends a signal and the KAKU doorbell sounds. So far so good, technically its working.
I'm using rfxcom with Domoticz. The problem is: I don't see the KaKu doorbell in the Domoticz logging, it looks like as if rfxcom does not pickup the signal.
On the other hand: I have added the doorbell as a switch in Domoticz, when I click this switch the KaKu doorbell is activated, rfxcom is transmitting. Why doesn't it pick up the signal when I push the doorbell ?
